Home > Technical > EGT - How hot??? |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2187 |
800 is about the highest i think. Dont turn the boost down, more air = lower EGTs.
24th Jul 2017 3:48pm |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 332 |
Ok - I will monitor it and see if the map allows decent EGTs. Its the full billet turbo and intercooler stage 3 map !
24th Jul 2017 4:50pm |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
If you're going to that expense, i'd get an EGT gauge fitted 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
24th Jul 2017 5:18pm |
I am about to fit one as part of the kit. I was just asking what range is ok and what is too high.
24th Jul 2017 5:21pm |
Proper job 1993 200 Tdi 90 CSW
24th Jul 2017 5:44pm |
tuesdayfox Member Since: 23 Jun 2013 Location: Sydney,OZ Posts: 129 |
Hmnnnnnn.....
I have one fitted to my puma 2.2 with bas 170 remap Highway 6th gear on slope 110kmh egt can go up close to 500 In city driving never goabove 300.... |
6th Oct 2017 5:31am |
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 |
Temperature figures given, are they pre or post turbo Tuesday fox?
6th Oct 2017 11:31am |
Hi mate
They are post turbo. I just used the blank plug to install the egt (as per Madman instructions The plug was used for dpf sensor but luckily we don't have these... What are your readings? Cheers |
6th Oct 2017 11:43am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8097 |
500 is no worries.
my tgv is tunned a fiar bit and will top 700 if you hold it in the gears, just drive to the EGT gauge! Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
6th Oct 2017 3:08pm |
My Alive down pipe doesn't have a facility for fitting a EGT probe. However a good remap and all the usual mods from what I understand should mitigate high prolonged EGT,s. That been said I would still like too have one fitted! The ultraguage gives me the CHT readings and a tell tale of when too ease up.
7th Oct 2017 2:44am |
More gauges, more problems
7th Oct 2017 5:49am |
^^^ yep Cheers
7th Oct 2017 6:21am |
