![]() | Home > Maintenance & Modifications > Bulkhead vent flaps |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2735 ![]() ![]() |
No on the flaps, as above.
dioliahary Member Since: 18 Jan 2015 Location: Manchester Posts: 668 ![]() ![]() |
Beltin now at the risk of being a pain.
Foam seals glued to the vents only? Just read a thread where they stuck foam to the flap and rubber to the bulkhead http://www.defendersource.com/forum/f6/ven...43884.html |
Procta Member Since: 04 Dec 2016 Location: Sunderland Posts: 5276 ![]() ![]() |
can you fit forms with out the need for removing the vent flap? I am sure the driver side one has seen better days, i am looking at working on the quick fixes at the moment. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
legin Member Since: 22 Jul 2017 Location: Chelmsford Essex Posts: 1004 ![]() ![]() ![]() |
One of the things I miss from my old defenders, why could they not keep them on the puma ?
They are well handy to have in the summer, Here is a funny story for you regarding these vents, When I bought 1st bought my landy, I never checked that the vents were shut properly at all, after a good two months or so driving up and down a 70 mph road with the very cold wind blowing through the front vents etc and here's me thinking that the heater takes and age to warm up. I thought about adding a plug in heater thing just to keep warm! It wasn't until my mum happened to walk past and clock that my vents were a good few mill up compared to theirs, she then twigged on about me saying about how cold it was. The handles were down about 3 to 4 clicks! so no the wonder procta here was turning to brass!
![]() So do make sure lads that they are well closed up for the winter! Last thing you want is to be brass monkeys going to work! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back In the words of my Good Friend, Gary Forrest 1980 -2025 " we will work something out" |
donmacn Member Since: 07 Nov 2017 Location: Nth Scotland Posts: 1886 ![]() ![]() |
I'm a regular messiah today - lots of thread resurrections....
After the advice and decision to fit foam, why go for rubber?? I think I'm going to need to have a look at mine again, so would like to go for whatever really does seal the best. Ta Donald Donald 1994 Defender 300Tdi 110 SW - owned since 2002 - 230k miles and going strong (The 'rolling restoration' or tinkering thread: http://www.defender2.net/forum/topic58538.html ) 2000 Range Rover P38 4.0L V8 in the past.. RR classic - fitted with 200Tdi 1984 RR classic - V8 with ZF auto box 1993 Discovery 300Tdi not to mention the minis and the Type 2 VW camper... |
defender9 Member Since: 12 Mar 2016 Location: Fylde Coast Posts: 1629 ![]() ![]() ![]() |
It's sunny in Manchester ![]() |
Changed from foam to rubber as it had a slight leak that showed itself in the drivers footwell. So foam was probably fine but as it had rubber originally replacing with rubber kept in line with original. Still got my leak btw.
