Home > Maintenance & Modifications > Bulkhead vent flaps
dioliahary
Bulkhead vent flaps
Mine are stuck down, painted over and do not work.
It gets rather hot in the defender when sunny, how useful is it to have the air vents working.
Thinking about stripping and cleaning.
Post #639170 23rd Jul 2017 3:21pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
Open flaps in summer is great ! well worth the effort . just make sure they are not hiding a bodged bulkhead
Post #639179 23rd Jul 2017 3:45pm
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Hi they definitely make a difference ,hopefully they were just sealed up because they were letting water in if that's the case give the levers a good spray of wd40 over a couple of days and run a Stanley blade around the vents and slowly open them and close them a little at a time don't try to open them fully the first push of the levers as if they've seized through not being used they may break,mine weren't stuck/sealed down but they were very seized up through lack of use and this did the trick,when you do release them make sure you order genuine vent seals as the pattern ones are rubbish,good luck you won't regret doing this Thumbs Up Paul Tash n Barney
Post #639229 23rd Jul 2017 6:47pm
dioliahary
Great stuff. Started the job, plenty of releasing agent. I intend to renew the split pins type things also however one has just sheared looks a simple but a Censored of a job to get it out.
Post #639231 23rd Jul 2017 6:57pm
familymad
I miss our TD5 vent flaps 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #639235 23rd Jul 2017 7:07pm
landroverdiver
I missed mine so much I got rid of the Puma and bought a td5!
Post #639240 23rd Jul 2017 7:46pm
dioliahary
Well ordered new OEM seals and stainless hinges off flea bay.
Got the drivers side working, will just have to figure a way of removing the hing pin.
Quite excited, will be able to ventilate rather than boil 👍
Post #639243 23rd Jul 2017 7:52pm
AMBxx
Look on the bright side - AIRCON!!
Thumbs Up
Post #639343 24th Jul 2017 7:02am
dioliahary
Quick question foam or rubbers seals, I have ordered the foam but thinking I should have ordered rubber instead
Post #639412 24th Jul 2017 4:35pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
African air-conditioning - you can't beat it! Euro-Leafing to infinity and beyond.....
Post #639430 24th Jul 2017 5:26pm
Barneyboy
Hi dioliahary I was advised foam when I ordered mine Thumbs Up Paul
Post #639434 24th Jul 2017 5:39pm
dioliahary
Will try the foam Thumbs Up
Post #639444 24th Jul 2017 6:13pm
dioliahary
Is it possible to fit the foam seals without undoing the bracket, I will have the hing pins released. Also I will have to retouch the paintwork. Would you fit the foam seal and paint or paint first.
Post #639466 24th Jul 2017 7:21pm
Retroanaconda
With the hinge pins off you can undo the bracket fixings easily enough, bit of a fiddle but doable kneeling on the bonnet.
Fix the paint, then stick the foam seals on the flaps. Then refit and close tightly for a day or two before first use. Ensure they sit flat-ish all round, so the foam is making contact with the metal lip on the bulkhead.
Post #639498 24th Jul 2017 8:21pm
dioliahary
The foam seals, do they stick onto the bulkhead...
Post #639508 24th Jul 2017 8:36pm
