Home > Technical > Defender td5 transmission oil |
AJC Member Since: 30 Nov 2015 Location: Lancashire Posts: 1364 |
i put fresh MTF is mine not so long ago. No issues
22nd May 2018 7:41am |
MJN110 Member Since: 18 May 2015 Location: North Yorkshire Posts: 380 |
Thanks again ZSD-Puma for your information.
I tried the faster gear change 1st to second when cold and I had perfect gear changes so that problem is solved and I will stick with the MTF gear box oil. 2016 Defender Landmark 90 2005 Defender CSW TD5 90XS |
25th May 2018 8:12am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2947 |
I use redline for the R380 copes much better with the heat when towing
25th May 2018 8:20am |
I will be towing on a regular basis fairly soon in what respect does the R380 cope better with redline? 2016 Defender Landmark 90
25th May 2018 8:43am |
It’s much smoother when cold I was quite surprised really I was looking for a better quality oil copes with heat well try it :
Have a read up |
25th May 2018 8:53am |
Do you mind telling me which Redline product you are using there seems to be 2 gearbox oils? 2016 Defender Landmark 90
25th May 2018 9:05am |
MTL not cheap but quality never is
25th May 2018 9:45am |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17475 |
Glad that trick works for you too! I still don't understand why it works, but it does. As stated above I really don't rate the R380 at all highly, Landrover was never very good at gearboxes but the R380 was surely one of the worst. Ford on the other hand was always very good at gearboxes (especially in the '60s and '70s). |
25th May 2018 11:06am |
LandymanStefan Member Since: 30 Aug 2017 Location: Surrey Posts: 881 |
What brand of mtf94 is everyone going for?
25th May 2018 12:34pm |
Mike c Member Since: 11 Aug 2017 Location: Maldon, Essex Posts: 930 |
I went for genuine LR, not cheap but thought it may be worth going for. Have not used it yet so unable to comment on the performance.
Mike |
25th May 2018 1:05pm |
