Home > Puma (Tdci) > my first problem out of warranty... gearbox leak
ralton
South Africa 2007 Defender 90 Puma 2.4 SW Zermatt Silver
Well, here i am in the world beyond warranty - just over 100K km (3 years and 1 month) and i noticed a "wet" spot under the gearbox.
I had the slave cylinder replaced 5 months ago - if i'm correct, this involves removing the gearbox?
If so, what sort of warranty should i expect for individual jobs?
Cheers www.ralton.co.za
Post #58826 13th Feb 2011 3:46pm
MK
If you are not sure it is clutch fluid then check on the gearbox oil level. Sometimes overfilling causes the oil to escape thorugh the breather. Puma 110" SW
Post #58832 13th Feb 2011 4:33pm
RobKeay
Not sure on tdci but td5 gearbox had auto transmission fluid which is red. Clutch fluid is clear and burns your hands. I've had a few slave cylinders go over the years and there easy to change. I would expect ur slave is still covered.
Post #58834 13th Feb 2011 4:41pm
fekete
Gear box out Big Cry
If its out of warranty then nothing is covered... if you need a new slave your looking about £700 for the dealer to do the job..... independent quoted me £270 Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #58855 13th Feb 2011 6:19pm
RobKeay
I would push for it to be covered since it was changed only 5 months ago. If it is a gearbox out job £270 great deal. Did it on my 200tdi a few weeks back in half hour the joys of simple engines, still need to bleed it through mind.
Post #58872 13th Feb 2011 7:12pm
fekete
Rob they have put the slave inside the bell housing Big Cry so its a pain in the arse to do the job..... i was quoted £780 of JE Chester and £270 of my independent LR said they would go half's with me...but it was still cheaper for me to pay full price with my independent than go half's with LR ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #58881 13th Feb 2011 7:46pm
RobKeay
Sounds bad for future home mechanics! Hope ur new one lasts!
Post #58910 13th Feb 2011 8:46pm
ralton
It's the Transfer case that's leaking. So, two questions:
Would this have been tampered with during a Slave cylinder replacement?
How do i check the oil level? www.ralton.co.za
Post #58954 14th Feb 2011 5:22am
