![]() | Home > Puma (Tdci) > my first problem out of warranty... gearbox leak |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 ![]() ![]() ![]() |
Well, here i am in the world beyond warranty - just over 100K km (3 years and 1 month) and i noticed a "wet" spot under the gearbox.
I had the slave cylinder replaced 5 months ago - if i'm correct, this involves removing the gearbox? If so, what sort of warranty should i expect for individual jobs? Cheers www.ralton.co.za |
RobKeay Member Since: 19 Jul 2009 Location: Stafford Posts: 1588 ![]() ![]() ![]() |
Not sure on tdci but td5 gearbox had auto transmission fluid which is red. Clutch fluid is clear and burns your hands. I've had a few slave cylinders go over the years and there easy to change. I would expect ur slave is still covered.
Gear box out ![]() If its out of warranty then nothing is covered... if you need a new slave your looking about £700 for the dealer to do the job..... independent quoted me £270 ![]() |
I would push for it to be covered since it was changed only 5 months ago. If it is a gearbox out job £270 great deal. Did it on my 200tdi a few weeks back in half hour the joys of simple engines, still need to bleed it through mind.
Rob they have put the slave inside the bell housing
Sounds bad for future home mechanics! Hope ur new one lasts!
It's the Transfer case that's leaking. So, two questions:
Would this have been tampered with during a Slave cylinder replacement? How do i check the oil level? www.ralton.co.za |
