Home > Td5 > 110 TD5 High Capacity refurb
Hawksthorn
United Kingdom 2004 Defender 110 Td5 HCPU Bronze Green
I'm sure this is going to be the first of many questions, I have recently purchased a 2004 Hi cap pickup, intention of complete strip down and rebuild/paint to a tidy working practical pickup. Stripping it back and replacing the chassis with a galvanised one and having the bulkhead galvanised. possibly raptor coating the body work.
I am well on with the strip down, the rear cross member is not good but salvageable, however the vehicle is for keeps so I'm going to do it once and hopefully properly hence a new chassis.
I have stripped it back to the stage where I need to remove the loom from through the bulkhead, my question is is do your remove the loom from the engine side of the bulkhead and poke it into the cab or strip it from the cab into the engine side, also where the rear loom goes to the lights will it pull back through the chassis member relatively easily or is it more prudent to cut and reconnect?
many thanks,
David
Post #624301 15th May 2017 1:20pm
zsd-puma
if you're scrapping the chassis you can always cut some extra holes in it to help pull the loom back through if need be.
Post #624332 15th May 2017 2:40pm
MadTom
I was repairing (welding) rear parts of 130 chassis. First I have pulled the loom from chassis, to protect from heat. After repair, I have placed the loon on the top of chassis, not inside. It was much easier, and it will not restrict later cleaning of the chassis internals. "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #624524 16th May 2017 7:32am
Hawksthorn
Many thanks guys.
Regards
David
Post #625393 19th May 2017 3:03pm
Hawksthorn
The loom is out , disconnect and pull through into cab. With the chassis it was pulled from the rear and out along with a couple of kilos of Somerset silt.
Post #625815 21st May 2017 6:38pm
corgi1
England 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
we need pictures all the way ITS THE LAW ! Rolling with laughter
Post #625820 21st May 2017 6:55pm
mk1collector
I agree many pictures all the way through the process please Thumbs Up Ray
My build thread
Post #625822 21st May 2017 7:06pm
