Home > Td5 > 110 TD5 High Capacity refurb |
if you're scrapping the chassis you can always cut some extra holes in it to help pull the loom back through if need be.
15th May 2017 1:40pm |
MadTom Member Since: 10 Sep 2013 Location: Olomouc Posts: 637 |
I was repairing (welding) rear parts of 130 chassis. First I have pulled the loom from chassis, to protect from heat. After repair, I have placed the loon on the top of chassis, not inside. It was much easier, and it will not restrict later cleaning of the chassis internals. "Drobek" = The Small One - Discovery 2, "BlufĂnek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo
16th May 2017 6:32am |
Hawksthorn Member Since: 10 Jan 2017 Location: Gloucestershire Posts: 34 |
Many thanks guys.
Regards David |
19th May 2017 2:03pm |
The loom is out , disconnect and pull through into cab. With the chassis it was pulled from the rear and out along with a couple of kilos of Somerset silt.
21st May 2017 5:38pm |
corgi1 Member Since: 26 Feb 2017 Location: bucks Posts: 440 |
we need pictures all the way ITS THE LAW !
21st May 2017 5:55pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772 |
I agree many pictures all the way through the process please Ray
21st May 2017 6:06pm |
