Home > Td5 > Central locking not working on both rear doors??
Williamraff
United Kingdom 2006 Defender 110 Td5 CSW Alveston Red
Hi folks,
As above I have no central locking function on either rear door whether I use the key or the remote - the other doors work fine.
My question is - are the rear doors operated by a separate, specific relay / fuse or is it just coincidence that both rear doors are playing up?
Many thanks, Will.
Post #622285 6th May 2017 11:46pm
mk1collector
Probably the wires broken in the rubber conduit between the b post and door on both sides. The wires breaking is quite common. Ray
My build thread
Post #622288 6th May 2017 11:57pm
Williamraff
Thanks, I will check them out Thumbs Up .
Post #622289 6th May 2017 11:59pm
jonny2tanx
United Kingdom 2005 Defender 110 Td5 XS CSW Alveston Red
Seconded. I have had to fix both of mine in the past year. Easy job
Post #622338 7th May 2017 8:54am
Gillan
United Kingdom 2009 Defender 110 Puma 2.4 HT Alaska White
Hi, mine started to be very intermittent then totally stopped working so I stripped them down and found the actuators to work fine with the fob but the white pivot pin was stiff to move so greased them up and all has been fine since Very Happy
Post #622459 7th May 2017 6:27pm
RG
United Kingdom 2001 Defender 110 Td5 SW Alveston Red
Any recommendation for the best grease to use?
Post #747474 26th Dec 2018 10:01pm
Adam17
England 2004 Defender 110 Td5 XS CSW Java Black
Interesting... as I have the driver side door not unlocking but locking... Regards
Adam
Loving The Duchess
The Defender 110 TD5 XS
My Defender story - http://www.defender2.net/forum/topic64005.html
Post #749741 7th Jan 2019 12:32pm
4RF RDS
That is likely a broken wire at the door jamb. Drivers door has all the wires (as in four or five wires) and the other doors just have two wires. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
1967 MGB GT
H. L. Mencken (1880 - 1956)
Post #749768 7th Jan 2019 4:13pm
Adam17
ok cool ill look at it, I also noted an error in my text, its the driver side passenger door. Laughing Regards
Adam
Loving The Duchess
Post #749769 7th Jan 2019 4:15pm
