Home > Td5 > Central locking not working on both rear doors?? |
Probably the wires broken in the rubber conduit between the b post and door on both sides. The wires breaking is quite common. Ray
6th May 2017 11:57pm |
Williamraff Member Since: 19 Mar 2017 Location: Leeds Posts: 40 |
Thanks, I will check them out .
6th May 2017 11:59pm |
jonny2tanx Member Since: 06 Jul 2014 Location: Harpenden, Herts Posts: 156 |
Seconded. I have had to fix both of mine in the past year. Easy job |
7th May 2017 8:54am |
Gillan Member Since: 01 Apr 2016 Location: Sheffield Posts: 35 |
Hi, mine started to be very intermittent then totally stopped working so I stripped them down and found the actuators to work fine with the fob but the white pivot pin was stiff to move so greased them up and all has been fine since
7th May 2017 6:27pm |
RG Member Since: 12 Sep 2016 Location: England Posts: 10 |
Any recommendation for the best grease to use?
26th Dec 2018 10:01pm |
Adam17 Member Since: 15 May 2018 Location: Within Bedfordshire Posts: 1193 |
Interesting... as I have the driver side door not unlocking but locking... Regards
Adam Loving The Duchess The Defender 110 TD5 XS My Defender story - http://www.defender2.net/forum/topic64005.html |
7th Jan 2019 12:32pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 932 |
That is likely a broken wire at the door jamb. Drivers door has all the wires (as in four or five wires) and the other doors just have two wires. 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
7th Jan 2019 4:13pm |
ok cool ill look at it, I also noted an error in my text, its the driver side passenger door. Regards
7th Jan 2019 4:15pm |
