Home > Puma (Tdci) > LED Indicator bulbs
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
LED Indicator bulbs
Can you fit replacement LED indicator bulbs without having to replace the flasher relay, which I believe, is behind the dashboard? Confused
Post #57049 6th Feb 2011 6:32am
jlerra
Gibraltar 2007 Defender 90 Puma 2.4 XS CSW Java Black
LED Indicator bulbs
Buy a relay from the 'mobile centre' (expensive at £22) and replace the original in the fuse box on the dash under the steering wheel (LHD) Then fit the bulbs - Easiest way.
Alternatively, you need to fit resistors on the wiring on each indicator lamp requiring cutting the original wire.
I carried out the first option and it's the best way.
If you don't do this you will get fast blinking.
Joe
El Pepe Flamenco JLS
'El Pepe Flamenco'
Post #57077 6th Feb 2011 9:51am
mse
Depends if the bulb has the resistor in to make the circuit think its a normal bulb...in which case, there is little point Mike
Post #57079 6th Feb 2011 9:52am
WelshGas
I'm not with the vehicle at present. Which relay is it? In the pdf manual I have I can't find any mention of it? Crying or Very sad
Post #57128 6th Feb 2011 1:58pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
In the PDF manual I have its on page 898. Item 5 in the diagram, top row, far right hand side. Immediately to the right of the wiper relay (you'll remember this one if you've done the intermittent wiper mod as per the other thread!).
Pete
Post #57285 6th Feb 2011 10:40pm
No resistor required ifvyou get the mobile centre relay hence the price
Post #57306 7th Feb 2011 4:36am
