Home > Maintenance & Modifications > NAS rear step - fixing bolts
Page 2 of 2 <12
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
Just a few left!
Fitted two step bumpers in that past, both to station wagons with the seat belt mount bracing inside wheel arch and the anti crush tubes already present...
 Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #618139 20th Apr 2017 1:33pm
stuart123
United Kingdom 2009 Defender 90 Puma 2.4 CSW Aintree Green
Awesome, thank you for looking.
You have mail... Smile
Post #618141 20th Apr 2017 1:52pm
Zim
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Not to depress you, but it may be worth having a really good look at your NAS step, mine looked pretty good when I took it off - it just looked like it had some surface rust in a few areas, I decided to get it shot blasted along with my side steps as I wanted to address some rust issues with the side steps. When it came back from shot blasting I was very surprised at the extent of the rust. I am busy treating the NAS step at the moment, I have treated and painted up the end plates - you can see the pitting in the end plate from the rust.
My NAS step is only 5 years old! 2007 Defender 90 XS
2022 Defender D300 HSE X-Dynamic
Post #618143 20th Apr 2017 2:22pm
stuart123
Thanks for that... it did look pretty shabby in that photo but having taken it off, its cleaned up really well and has since been shot blasted and powder coated and looks like new again Smile
Post #618147 20th Apr 2017 2:47pm
X4SKP
Zim is so right...
The 'tin' plate under the Rubber Tread is not really up to it... Shocked
Mine too a 3 years was all looking a bit sad, this was a basic make do and refinish,
hopefully i'll replace the Tread Plate this year, removing the power coating
in the process too, and refinish again. Still like the general product, just a few
areas of substandard specification / material choice, oh and the finishing is... Crying or Very sad
 SKIP
Post #618158 20th Apr 2017 3:14pm
sidewinder
Apologies for the tread resurrection.
I have a Nas step but didn't get the retaining stays that go back to the chassis with it.
Could you possibly post up dimensions for the retaining stays and the additional cross brace between them to allow me to get something made up.
Thanks
Post #962481 22nd Aug 2022 8:23am
donmacn
Hi there,
You'd need to say whether you have a 90 or a 110, and what age? I think there would be differences in the chassis and stays.
I have an NAS fitted to my 110 and could provide some dimensions if that was any use. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #962505 22nd Aug 2022 11:46am
sidewinder
Thanks Donald,
Schoolboy error!
I have a 1989 90. Hopefully someone can provide me with he corrected dimensions.
Failing that what are the stays made of? Is it just flat bar or is it angle?
If you could let me know the width and thickness of the angle / bar I could make something up.
Regards
Post #962523 22nd Aug 2022 2:24pm
donmacn
No worries.
On mine (a 110) and, if my memory's right, on a friend's 90 which we took a NAS step from recently, the stays were steel box section, with a couple of angles. I haven't the car with me just now, but I could easily post pics later this evening.
That said, I can't see any reason why some suitably robust bar wouldn't do the job - it works for the standard LR towbars. Donald
in the past..
Post #962524 22nd Aug 2022 2:32pm
sidewinder
Thanks.
Pics would be handy if you get a chance.
Post #962579 22nd Aug 2022 11:00pm
90 Dreamer
A few of my soon to be replaced slightly rusty one on a MY16 90
Post #962638 23rd Aug 2022 4:10pm
sidewinder
Many thanks.
Looks like inch bar 3-5mm thick will do the job.👍
Post #962700 23rd Aug 2022 9:05pm
I'd suggest you want something thicker than 3 to 5 mm. That's only 1/8" to 3/16" in old money (to match your inch).
Post #962702 23rd Aug 2022 9:53pm
sidewinder
Thanks.
Do you happen to know the thickness and width of ones that come with the tow bar?
I can fit the step and sort out the lengths.
Post #962717 24th Aug 2022 7:49am
Page 2 of 2 <12
