![]() | Home > Puma (Tdci) > Metalic squeel at 2000rpm. Turbo? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17711 ![]() ![]() ![]() |
First things I would check are (1) split in pipe from turbo to intercooler, which is a common problem and can be very hard to spot, and (2) blowing gasket between manifold and turbo or head and manifold. Any of these can produce the symptoms you describe.
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
OK thanks. Sure it wont be the pipes as new ish but will look at the gasket Chris
2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
If the pipe has been recently fitted, check that it isn't being rubbed by the steering column joint where the column enters the box. This is the most common cause of pipe failure.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
Try and source where the oil coming from.
Could be alt failing or tensioner or other pulley loading the engine. Squealing usually a dried out bearing. Had a td5other day suspected seized engine as wouldn't turn over. Just had a seized idler puller. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Oil spots on the front of the trailer may be the rear diff pinion seal.
or t box seal.
i think the two are unrelated. try running it ancil belt off see if it still squeals. if it was turbo bearing gone you would get burnt engine oil and massive over fuelling with black smoke. i presume it does it engine speed related only? ie always at 2000rpm irrespective of road speed? Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 ![]() ![]() |
Could be Turbo manifold gasket, the OEM is not of high quality. I would look at replacing it for the Nakatanenga just in case. 2016 Defender 90 Adventure Edition |
Thanks
Anybody have a link to where I can buy one from?? I not got arround to looking at it yet ![]() Have booked it in with Zag for a rust treatment though ![]() 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
tonyt Member Since: 30 May 2015 Location: sydney Posts: 3 ![]() ![]() ![]() |
