Home > Puma (Tdci) > Metalic squeel at 2000rpm. Turbo?
Dieselhead
Hi,
I have a very annoying screaching/ vibrating noise at just over 2000rpm
No its not the heat shield as it not fitted atm Rolling Eyes Rolling Eyes
It will do it hot or cold only when your driving. not when stationary
I keep wondering if its the turbo as it not been as lively as its been for a while now.
It always used to rev hard when static but wont go over 3000rpm now. Yes I no some dont but would cause it to just not rev any more now??
If the turbo modulator is faulty would that limit the revs?? Can the turbo make a noise if its faulty?
I was towing the other day & I had a load of oil spots on the front of the trailer when I got home Confused
Any thoughts?? Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #617313 16th Apr 2017 9:00pm
First things I would check are (1) split in pipe from turbo to intercooler, which is a common problem and can be very hard to spot, and (2) blowing gasket between manifold and turbo or head and manifold. Any of these can produce the symptoms you describe.
Post #617538 17th Apr 2017 8:22pm
Dieselhead
OK thanks. Sure it wont be the pipes as new ish but will look at the gasket Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #617549 17th Apr 2017 8:50pm
If the pipe has been recently fitted, check that it isn't being rubbed by the steering column joint where the column enters the box. This is the most common cause of pipe failure.
Post #617575 17th Apr 2017 10:06pm
jst
Try and source where the oil coming from.
Could be alt failing or tensioner or other pulley loading the engine.
Squealing usually a dried out bearing.
Had a td5other day suspected seized engine as wouldn't turn over. Just had a seized idler puller. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #617597 18th Apr 2017 6:31am
Oil spots on the front of the trailer may be the rear diff pinion seal.
Post #617601 18th Apr 2017 7:14am
jst
or t box seal.
i think the two are unrelated.
try running it ancil belt off see if it still squeals.
if it was turbo bearing gone you would get burnt engine oil and massive over fuelling with black smoke.
i presume it does it engine speed related only? ie always at 2000rpm irrespective of road speed? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #617654 18th Apr 2017 11:30am
SkyFallSilver
Kuwait
Re: Metalic squeel at 2000rpm. Turbo?
Dieselhead wrote:
Hi,
Any thoughts??
Could be Turbo manifold gasket, the OEM is not of high quality. I would look at replacing it for the Nakatanenga just in case. 2016 Defender 90 Adventure Edition
Post #622816 9th May 2017 7:58am
Dieselhead
Thanks
Anybody have a link to where I can buy one from??
I not got arround to looking at it yet Rolling Eyes
Have booked it in with Zag for a rust treatment though Cool Chris
1983 Mini Mayfair
2004 VW T5 Camper
Post #623258 10th May 2017 9:04pm
tonyt
Australia 2013 Defender 110 Puma 2.2 SW Alaska White
Dieselhead wrote:
Hi,
spray some lube on the pulley
Any thoughts??
Post #627888 31st May 2017 6:25am
