![]() | Home > Maintenance & Modifications > A day in the life of Miffy the 110... |
It's like Christmas just without the sprouts and wasted paper
![]() ![]() Click image to enlarge And inside... ![]() Click image to enlarge Can you guess what it is yet???? ![]() Click image to enlarge Oh yes... Full set of Cupronickel brake lines for the old girl. During this years MOT there was an advisory on the long chassis pipe and since I know the front caliper pipes are also looking a little sad I think this Christmas the Miffy deserves some new arteries... I love flaring brake pipes, but I have stupidly lent my gear away and have not seen it since. Balls... I am really impressed by the quality of the flared ends, everyone is perfect and every line is numbered for ease of fitment. ![]() Click image to enlarge ![]() Click image to enlarge But all this has meant buying new tools and who doesn't just love buying new tools ![]() So the question is... What is the best way straighten the lines prior to bending?! Hmmm... Not sure, not sure... Maybe two pieces of wood with a notch cut in them with which to pull the pipe though and so straightening it... Whatever, it needs to be a clamp over solution because of the flared ends... Any ideas folks? |
It is a strange thing but in this world of modern technology I get so much pleasure out of using two products that have their genesis in a period of ration books and a lack of lemons... The Defender and the Aga ![]() I do love Aga toast and pancakes ![]() ![]() ![]() |
For reference this is the label numbering key diagram for a Defender 110 TD5 2003 non-ABS with proportioning valve.
matchap801 Member Since: 05 Aug 2021 Location: Somerset Posts: 120 ![]() ![]() ![]() |
Hi. Who did you get the brakes pipes from? I am after a set for my Puma and looking for some decent quality but reasonably priced ones. Thanks. Matthew
Yes you are right, but I was pondering on a better way to actually get them straight rather than the usual DIY way by hand that inevitable leaves the pipe wavy… I expect this is what will happen but as a DIY thought experiment I am curious is all… |
Hi Mathew. I got them off this guy (Rowan) on eBay. He does a whole load of different classic cars. If you cannot find what you are looking for drop him a message and he will direct you to the item you need. You can find him here: [url] https://www.ebay.co.uk/itm/Land-Rover-Defe...58-0[/url] |
Brilliant thank you. I will drop him a message. They are needed for the MOT in March so slowly going through the list.
3 steering ball joint and drop arm ball joint done this weekend - what a nightmare! A-Frame ball joint also needed. I really wasn’t looking forward to buying all the bits and flaring kit and doing all at home 👏 |
Another bit of the puzzle arrived this morning... A pair of pliers and some grease
![]() ![]() These are a fantastic tool to have in your toolbox for quick brake pipe adjustments or tight bends ![]() The other bit is the rubber grease for the rebuilding of the callipers and replacing the brake pipes. Good fun. Wonder if I can borrow a barn for a weekend to get this job done... ![]() |
Indeed. So many different types out there. What is confusing me is whether the flared ends are single, double, ISO, DIN or whatever else. All appear to be a little different 🙈🤯🤹♀️
A belated Merry Christmas from Miffy and myself.
This Christmas Miffy received some super bits courtesy of my in Laws. I think they may understand me ![]() ![]() From my brother in law Miffy got a new seat base foam which is the first bit of the seat refurb. There is some "discussion" whether this base should be put towards the passengers (Wife) or the drivers comfort... Something about gentlemanliness or something ![]() Then from the Mother on law came these items, good ol British toilet humour including a couple of knobs ![]() ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge I am rather chuffed with these. The quirkiness of the pseudo-historic looking gear knobs will match the overdrives knob rather well. As for the bog roll holder. Excellent ![]() The only downside tot he bog roll bag is the lack of space for matches... Hmmm going to need a cylindrical match holder i think to fit inside the roll... Obviously, it wouldn't be complete without an Emergency Roll in danger red paper :rofl: Wonderful gifts ![]() |
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3527 ![]() ![]() ![]() |
Have you already straightened the brake pipe?
The normal way of straightening coiled material is to pass it through at least 3 rollers. Just 2 blocks of wood clamped over the pipe might not be enough because of material spring back. What you could try is a piece of plywood ( clamped to a solid work bench) to which you clamp 3 smaller blocks of wood in a triangular pattern. The block of wood at the apex should be adjusted such that when you pull the end of the pipe, you get a straight pipe. Over adjusting will bend it the other way so you might have to do some trial and error until you are happy with the result. You would probably have to lubricate the wooden blocks (or ideally use pulleys as the rollers). 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing 2012 90 CSW, 2.2TDCI, Santorini Black |
Well it had to be done eventually, so here they are the Christmas knobs courtesy of Mud Stuff.
Before and standard LR: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge After: ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Not yet. That is a job for a drier day. It hasn't stopped drizzling for over a week now ![]() I have thought about two pieces of wood with a groove for the pipe to pass through. Worth a try, what could possibly go wrong ![]() |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5889 ![]() ![]() ![]() |
Geobloke, do you use Miffy for your geo (surveying?)? Do you have a full camp set up? How does it work? Any photos? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
