Home > Technical > ??? What Has Gone Wrong???
Page 2 of 2 <12
jst
change the mater and reverse pressure bleed it Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #614305 3rd Apr 2017 6:53pm
agentmulder
Kuwait
Yes, had to do this to get the bubble trapped in the line where it goes up and over the ECU on my puma 2.4.
Design is just asking for it IMO Solved the bowel problem, working on the consonants...
Post #614326 3rd Apr 2017 7:59pm
Stiff1
So went to move it this evening...
Had parked nose in so thought ignition off, low range, into reverse, clutch pushed down for good measure, start. All went well and found I had a small amount of clutch control at the very end of the travel, enough to come out of reverse and into first, then second for some very slow manoeuvring out of parking area.
Could also take it out of low range and back into high, all be it really pushing the pedal down and onto first, second and all the way home.
Once arrived though would not select reverse, a few pumps of the pedal and reverse engaged, controlled and now parked up.
Does this information focus the diagnosis any further and thank you once again for all the input?
Post #614362 3rd Apr 2017 10:56pm
jst
Confirms hydraulic leak as pressure gained by pumping. Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #614380 4th Apr 2017 6:16am
Stiff1
So looking on the bay, very little listed specifically for the 2.4 / TDci and suspect the part has not changed for many years.
This listing seems to confirm that at this early hour.
Can any one confirm this item will be OK?
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...0939408761
Post #614383 4th Apr 2017 6:32am
dorsetsmith
your link being redirected
slave UUB500040 superseded by #LR068979
master STC500100
http://www.brit-car.co.uk/product.php/1955...ma_def_07_
Post #614386 4th Apr 2017 6:51am
Stiff1
Ebay link seems fine here.
Anyway, thanks for your link, they offer these:
Any preference jump out, tempted to go for above average with the TWR item or should I stick with genuine and pay the premium or just go with the Bearmach one at £10
Post #614401 4th Apr 2017 7:27am
dorsetsmith
Ebay link seems fine here. must be internet thinking Whistle
http://www.viglink.com/shop/query/land+rov...100/page/2
Post #614408 4th Apr 2017 7:38am
dorsetsmith
link only to shown you as not in stock
Post #614419 4th Apr 2017 8:27am
Stiff1
Yes but just wondered if members would be as happy with the Bearmach branded one as the others?
Post #614441 4th Apr 2017 9:51am
Stiff1
Update ??? What Has Gone Wrong???
So... have been advised that it is prob a "pin" they may have said in slave cylinder and if doing that might as well do full clutch kit at the same time so what I hoped would be £50 on now looks like £500 ish.
Forum thoughts
Post #614587 4th Apr 2017 10:02pm
agentmulder
Kuwait
I did new clutch on mine, but it depends...
mi/kms on your current?
In my case they made the decision after they opened it, I got the old clutch back to see ... I guess they could have given me anything, but I trust these folk enough to not think on it. Solved the bowel problem, working on the consonants...
Post #614594 5th Apr 2017 3:19am
Page 2 of 2 <12
