![]() | Home > V8 > The adventures of the V8_Ninety |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10383 ![]() ![]() |
Uh
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 ![]() ![]() |
I run a Defender 50th with the 4.0L GEMS V8 and don't have any extra cooling holes or fancy exhaust wrap; although the whole lot gets warm, the temp gauge stays where it should and the engine doesn't overheat.
It does have the proper radiator; with oil cooler. (which is bloody expensive to replace compared to others); so is either rare or has some extra cooling... The 50th has aircon with an additional radiator for cooling the gas and twin electric fans, these are only for air con purposes and controlled by the ECU. If excessive engine temp the air con stops working, so I guess LR looked into all the cooling. Standard viscous fan that comes in/out of locked when at normal temp, again suggests all is ok The 50th doesn't have side vents in the wings either. The only thing I've done is change the drivers top wing vent from solid to a grill, more for aesthetics has its a nice aluminium and stainless grill rather than plastic, so it should let some warm air out. Extra holes will always help; but not a necessity; a radiator in good condition and a working fan should be sufficient. |
Blanc Member Since: 14 Jul 2016 Location: Suffolk Posts: 43 ![]() |
Mine has never looked like overheating. It just kicks out heat like nothing else I've owned.
Running temperature is spot on, everything is new so no worries there.
RR
Always love the sound of a V8 and yours is spectacular Greeni
![]() 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10973 ![]() ![]() |
Thats my fix for tonight
![]() ![]() ![]() ![]() ![]() ![]() 1996 Golf Blue 300Tdi 110 Pick up. Keeper. |
Pickles Member Since: 26 May 2013 Location: Melbourne Posts: 3792 ![]() ![]() ![]() |
Sounds lovely Greeni,...I can't remember if you've ever put up a sound video of that V8 working really hard?..flat out drive by etc, in maybe 3rd or 4th?...don't know how many gears you have!
Pickles. |
Thanks guys.
A mate has just bought a GoPro drone....I'll see what I can do ![]() |
^^^^ Awesome
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 523 ![]() ![]() ![]() |
Looking savage Greeni, mad to get mine on the road after hearing the purr.
Been caught up in house DIY, haven't been on here in a bit ![]() |
Nice to hear from you. Hope things are good with your new addition
RS
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6163 ![]() ![]() ![]() |
Although if the 50th is as closely related to the NAS V8's, then there will be a regulator in the temp guage loom to fool you into thinking the temperature is staying constant. It's just a voltage regulator to keep the needle somewhere in the middle ![]() ![]() ![]() |
