Home > V8 > The adventures of the V8_Ninety
Page 7 of 10 <12345678910>
Blanc
Thanks Greeni. Very interesting.
After swapping from a cold running tdi I'm paranoid about heat. Everything to do with the V8 is so hot. It seems perfectly able to regulate itself but seems to radiate from everywhere.
The heater is very good though!
D.
Post #643505 12th Aug 2017 7:51pm
Uh
Post #643515 12th Aug 2017 8:47pm
V8GPC
I run a Defender 50th with the 4.0L GEMS V8 and don't have any extra cooling holes or fancy exhaust wrap; although the whole lot gets warm, the temp gauge stays where it should and the engine doesn't overheat.
It does have the proper radiator; with oil cooler. (which is bloody expensive to replace compared to others); so is either rare or has some extra cooling...
The 50th has aircon with an additional radiator for cooling the gas and twin electric fans, these are only for air con purposes and controlled by the ECU. If excessive engine temp the air con stops working, so I guess LR looked into all the cooling.
Standard viscous fan that comes in/out of locked when at normal temp, again suggests all is ok
The 50th doesn't have side vents in the wings either.
The only thing I've done is change the drivers top wing vent from solid to a grill, more for aesthetics has its a nice aluminium and stainless grill rather than plastic, so it should let some warm air out.
Extra holes will always help; but not a necessity; a radiator in good condition and a working fan should be sufficient.
Post #643602 13th Aug 2017 12:32pm
Blanc
Mine has never looked like overheating. It just kicks out heat like nothing else I've owned.
Post #643717 13th Aug 2017 9:59pm
Running temperature is spot on, everything is new so no worries there.
Post #643727 13th Aug 2017 10:17pm
RR
Post #645796 23rd Aug 2017 6:50am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Always love the sound of a V8 and yours is spectacular Greeni Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #645805 23rd Aug 2017 7:41am
L110CDL
Thats my fix for tonight Very Happy Very Happy Very Happy Very Happy Very Happy many thanks GREENI Bow down Clayton.
Keeper.
Post #645963 23rd Aug 2017 9:25pm
Pickles
Sounds lovely Greeni,...I can't remember if you've ever put up a sound video of that V8 working really hard?..flat out drive by etc, in maybe 3rd or 4th?...don't know how many gears you have!
Pickles.
Post #645993 23rd Aug 2017 11:25pm
Thanks guys.
A mate has just bought a GoPro drone....I'll see what I can do Mr. Green
Post #646014 24th Aug 2017 6:34am
L110CDL
^^^^ Awesome Cool Clayton.
Keeper.
Post #646149 24th Aug 2017 8:51pm
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Looking savage Greeni, mad to get mine on the road after hearing the purr.
Been caught up in house DIY, haven't been on here in a bit Sad
Post #646243 25th Aug 2017 11:35am
Nice to hear from you. Hope things are good with your new addition Thumbs Up
Post #646342 25th Aug 2017 9:14pm
RS
Post #646603 27th Aug 2017 5:33pm
Although if the 50th is as closely related to the NAS V8's, then there will be a regulator in the temp guage loom to fool you into thinking the temperature is staying constant. It's just a voltage regulator to keep the needle somewhere in the middle Shocked Shocked Shocked
Post #646605 27th Aug 2017 5:43pm
