Home > Puma (Tdci) > 2.4 "clacking"!
Page 1 of 3 123>
Pinky
England 2011 Defender 110 Puma 2.4 DCPU Baltic Blue
2.4 "clacking"!
I have a 2.4 TDCi in my 2011 110 defender... I have owned it a couple of years or so now and already had a MAF sensor, MAP sensor, SCV, PRV, blanked EGR and a remap. It was running sweet until a few weeks ago when it started making a "clacking" noise. Only does it when driving, nothing when sat still at any revs.
It burns no oil, starts on the button and when cold from overnight produces a small amount of blueish white smoke for about a minute. When it's cold it sounds fine, a few minutes after it's up to temperature it starts to make a clacking noise when at neutral revs. If you accelerate hard it sounds better and off the throttle it sounds fine but in traffic or just holding a moderate speed it sounds like a tractor! The longer you drive the worse it sounds. Even after a reasonable time cooling down it still sounds bad, it gets so bad that people turn and look to see what's coming.
I have had the cover off and the injectors are tight but look slightly moist around the seal at the base, I can't say wet, but definitely not dry.
One garage just said "they all sound like that", the other said " it could be the injectors but don't want to mess with them".
I'm very frustrated as I know how it used to sound but it doesn't now! It still runs well but generally sounds a little noisier than normal even when it's not "clacking".
It doesn't seem to be giving the normal symptoms of failing injectors or seals, there is no chuffing sound or gasses from rocker cover. I have got it booked into an injector specialist early next week just to rule them out but it's getting louder and I think it might fail before then! What do failing big or little ends sounds like or camshaft, or oil pump?
I'm beginning to think I will have to let it break to find out the cause! Big Cry
Any pointers gladly accepted.
Post #613306 30th Mar 2017 2:30pm
zsd-puma
Have you tried the old trick of putting a screw driver on various components and listening to the end of it? (automotive stethoscopes are cheap too) If it is a vac pump of something then that will help you pin point it.
Does it go quiet when you depress the clutch pedal?
Post #613315 30th Mar 2017 3:25pm
Pinky
It doesn't do it when sat still. only when driving. No difference with clutch in or out Neutral
Post #613321 30th Mar 2017 4:04pm
zsd-puma
Ahh ok, that kind of suggests it's a problem in the drive train rather than engine related.
Post #613324 30th Mar 2017 4:30pm
Pinky
No, definitely in the engine somewhere, it only happens under load and at certain revs.
Post #613326 30th Mar 2017 4:40pm
dorsetsmith
Post #613327 30th Mar 2017 4:48pm
Pinky
I've got the ashcroft upgrade, fitted with new clutch in 2015.
I've got a wav file that you can just about hear it on, cant figure how to add it here but it's in my gallery.
Post #613333 30th Mar 2017 5:11pm
dorsetsmith
Ok cross that one off the list
stones in between brake disc and shield
Post #613335 30th Mar 2017 5:23pm
Pinky
No, that would make a noise when moving with or with out engine. Have a listen to the wav, it's fairly obvious if you listen a couple of times and filter out the normal Defender din!
Post #613337 30th Mar 2017 5:30pm
dorsetsmith
Post #613341 30th Mar 2017 6:05pm
dorsetsmith
I hate to say it sounds ok i me Whistle
Post #613344 30th Mar 2017 6:09pm
Pinky
You wouldn't say that if you were driving it! People in the street are turning round to see what's making so much noise Whistle
Post #613347 30th Mar 2017 6:18pm
dorsetsmith
trouble is my heading tuned to TD5 defenders
Post #613349 30th Mar 2017 6:21pm
dorsetsmith
if you place transfer box in neutral make same sound ?
a frame ball clacking then drive off
also are all prop shaft UJ ok
Post #613356 30th Mar 2017 6:37pm
Dieselhead
Timing chain??
Must be something loose? Chris
2008 XS 110 2.4 Utility. Tonga Green
1953 Series 1 for restoration
1983 Mini Mayfair
2004 VW T5 Camper
2008 Diahatsu Sirion. Thats hers
Classic Bolens Garden Tractors
Post #613371 30th Mar 2017 7:28pm
Page 1 of 3 123>
