![]() | Home > Puma (Tdci) > 2.4 "clacking"! |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
Have you tried the old trick of putting a screw driver on various components and listening to the end of it? (automotive stethoscopes are cheap too) If it is a vac pump of something then that will help you pin point it.
Does it go quiet when you depress the clutch pedal? |
Pinky Member Since: 09 Jun 2016 Location: England Posts: 210 ![]() ![]() ![]() |
It doesn't do it when sat still. only when driving. No difference with clutch in or out
Ahh ok, that kind of suggests it's a problem in the drive train rather than engine related.
No, definitely in the engine somewhere, it only happens under load and at certain revs.
Output shaft main gear box
![]() http://www.defender2.net/forum/topic46497.html |
I've got the ashcroft upgrade, fitted with new clutch in 2015.
I've got a wav file that you can just about hear it on, cant figure how to add it here but it's in my gallery. |
Ok cross that one off the list
stones in between brake disc and shield |
No, that would make a noise when moving with or with out engine. Have a listen to the wav, it's fairly obvious if you listen a couple of times and filter out the normal Defender din!
I hate to say it sounds ok i me
You wouldn't say that if you were driving it! People in the street are turning round to see what's making so much noise
trouble is my heading tuned to TD5 defenders
if you place transfer box in neutral make same sound ?
a frame ball clacking then drive off also are all prop shaft UJ ok |
Dieselhead Member Since: 21 Oct 2012 Location: Pulborough. West Sussex Posts: 552 ![]() |
Timing chain??
Must be something loose? Chris 2008 XS 110 2.4 Utility. Tonga Green 1953 Series 1 for restoration 1983 Mini Mayfair 2004 VW T5 Camper 2008 Diahatsu Sirion. Thats hers Classic Bolens Garden Tractors |
