Home > Puma (Tdci) > This weird fuse holder |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
its a mega fuse designed to blow if you get a short to earth on the positive cable before the cable melts or the battery explodes or the car catches fire , no problem removing it but you loose all the protection mentioned if you do get an earth on the main cable DEFENDER 90 TDCI XS,
20th Mar 2017 6:54pm |
JoeLouw Member Since: 09 Mar 2017 Location: PTA Posts: 5 |
Makes total sense thank you. So one can use a different type fuse then instead if you like. Like an inline one.
What Amps would you recommend? And then I would assume to place it first inline out from out of the batteries + terminal. Joe |
20th Mar 2017 6:59pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20358 |
If you open it, the rating should be printed on the fuse its self.
$W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
20th Mar 2017 8:23pm |
there was another thread on here and I think it was said it is 400 amps also shown on the drawings but please check
http://www.defender2.net/forum/topic51411....=mega+fuse DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
20th Mar 2017 8:24pm |
