Home > Puma (Tdci) > This weird fuse holder
JoeLouw
South Africa 2008 Defender 110 Puma 2.4 SW Orkney Grey
Gents
Does anyone know the use of this useless weird looking fuse on the + cable running to the battery?
I like to know is it safe to remove it? and run without it?
Joe
Post #610936 20th Mar 2017 7:43pm
LR90XS2011
its a mega fuse designed to blow if you get a short to earth on the positive cable before the cable melts or the battery explodes or the car catches fire , no problem removing it but you loose all the protection mentioned if you do get an earth on the main cable DEFENDER 90 TDCI XS,
Post #610946 20th Mar 2017 7:54pm
JoeLouw
Makes total sense thank you. So one can use a different type fuse then instead if you like. Like an inline one.
What Amps would you recommend? And then I would assume to place it first inline out from out of the batteries + terminal.
Joe
Post #610947 20th Mar 2017 7:59pm
If you open it, the rating should be printed on the fuse its self.
Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #610980 20th Mar 2017 9:23pm
LR90XS2011
there was another thread on here and I think it was said it is 400 amps also shown on the drawings but please check
http://www.defender2.net/forum/topic51411....=mega+fuse DEFENDER 90 TDCI XS,
Post #610983 20th Mar 2017 9:24pm
