Home > My Defender > hanks Double Cab
Page 19 of 22 <123 ... 1819 202122>
hank
Defender has been running great when cold, but developed a rough idle when hot.
Also the injector learn process would not complete which is a sure sign that an injector is on the fritz
I have had this before which turned out to be a defective PF Jones reconditioned injector - refer to my previous post https://www.defender2.net/forum/topic53240-217.html
When cold all injectors read the same resistance (0.8ohms)
So again I ran it until hot then when the rough idle started went through the process of disconnecting each injector in turn:
Unplug injector 1 - engine almost conks out
Unplug injector 2 - no change to idle running
Unplug injector 3 - engine almost conks out
Unplug injector 4 - engine almost conks out
Injector 2 resistance also read way off compared to the others when hot. (I forget the reading now unfortunately)
So injector 2 was a dud.
I ordered another brand new (not reconditioned) Denso injector, fitted it, coded the ECU, got the engine up to temperature and went through the injector learn process…
Once again back to firing on all cylinders
Moral of the story again - don’t waste your time and money on reconditioned injectors Big Cry
First PF Jones reconditioned injector lasted 500 miles. Second one lasted 4000 miles.
Originals did 88,000 and were ok. They were only replaced as a preventative measure. What a mistake Laughing
Expensive error. Injectors 1 and 3 left to replace. Will do them next month.
 > 110 XS Double Cab
Post #995198 5th Jun 2023 5:26pm
I sometimes wonder if I would notice a difference if I replaced my injectors. They are original, have done very nearly 270k miles, and by my reckoning each one has by now squirted something like 2500 gallons of fuel (or half a typical road tank wagon load) into its cylinder. That's a lot of fuel through a tiny orifice! The fuel pump is also the original.
Mind you I have probably jinxed it now by writing this, and something will fail tomorrow. Surprised
Post #995205 5th Jun 2023 6:03pm
hank
Blimey that is a lot of diesel Shocked
But if it ain’t broke don’t fix it - I wish I’d taken heed of this age old advice!
The issue, as seems to be the case with everything these days, is quality assurance isn’t it. You put your faith in a “specialist company” and they sell you toss.
At least when injectors come out of the Denso factory you can have some level of confidence that they are right. > 110 XS Double Cab
Post #995264 5th Jun 2023 9:41pm
hank
Defender developed a clunk at the front end which seemed to happen when changing direction (forward and reverse).
Was tricky to diagnose/locate but turned out that the radius arm bolts at the axle end were loose.
Looks as though the mechanic that fitted my superpro polybush kit tightened the bolts finger tight Laughing
Another reason why I prefer to undertake maintenance myself > 110 XS Double Cab
Post #995289 6th Jun 2023 8:29am
kenzle8a
Even when I do I now mark all my major bolts on vital components with torque seal paint, its such a good sanity check.
Post #995296 6th Jun 2023 9:32am
hank
Flew through the MOT once again Thumbs Up
Had an advisory for drag link ball joint so thinking of sticking a sumo bar kit on.
Also had an advisory for tyres protruding beyond wheel arches…
In other news Fred joined the clan on the 9th June at 8lb 2oz.
 > 110 XS Double Cab
Post #996372 15th Jun 2023 1:03pm
L110CDL
Congrats on the arrival of Fred Very Happy
Great with a new mot on the DC Thumbs Up Clayton.
Keeper.
Post #996418 15th Jun 2023 9:00pm
Co1
I hope Fred comes with a good warranty and after service from the dealer? Have you got any mods planned yet?! Whistle
Post #996435 16th Jun 2023 5:40am
Screbble
Fred looks well Thumbs Up and exactly the correct size to easily carry out works such as Discovery drop arm conversion and Sumo Bar installation 👍
Post #996440 16th Jun 2023 7:41am
tommac
United Kingdom 2001 Defender 110 Td5 DCPU Alveston Red
Congrats on Fred’s arrival- no doubt he’ll have a spanner in hand in no time!
Post #996798 18th Jun 2023 9:54pm
hank
Boring update. Two new genuine DENSO injectors to replace the remaining two shonky PF Jones remanufactured ones left in my engine.
 > 110 XS Double Cab
Post #1013550 1st Nov 2023 6:00pm
hank
Boring post #2 alert...
Shiny new bits to fix the wipers have arrived. Looks as though I have a crap weekend ahead
 > 110 XS Double Cab
Post #1013668 2nd Nov 2023 5:17pm
Welshsurferdude
Wales
trucks looking good as I rode past earlier Thumbs Up 2011 Santorini Black USW XS.
2015 Discovery 4.5 Black pack Firenze red XS
Post #1013718 2nd Nov 2023 10:17pm
hank
Wheel boxes and rack are done and it wasn’t as bad a bad job as I had anticipated.
To be honest the rack and wheel box pinions were in pretty good condition. However the drivers side spindle had seized. Pair of new wheelboxes and a new rack fitted so should be right for another 15 years.
I didn’t get many pics as I was mainly working by torchlight
Dash pulled forward
Old rack - condition wasn’t too bad but replaced with a new genuine JLR part anyway.
New rack fitted to the motor
 > 110 XS Double Cab
Post #1013919 4th Nov 2023 5:47pm
hank
Cheers Ken. The old girl doesn’t get a lot of use now > 110 XS Double Cab
Post #1013975 5th Nov 2023 8:30am
