Home > My Defender > hanks Double Cab |
hank Member Since: 12 Sep 2016 Location: South Wales Posts: 2314 |
The newly built Ashcroft LT230 arrived today so hoping to get it fitted Saturday.
Click image to enlarge > 110 XS Double Cab |
12th Dec 2022 1:40pm |
Swapped out the transfer box today so the old girl is back on road.
Wasn’t too bad, took about four or five hours with the help of my Dad. Couldn’t get diff lock initially but realised I’d managed to refit the linkage backwards - not even sure how that was possible! Ashcroft output shaft still looking mint after all this time Click image to enlarge Click image to enlarge Click image to enlarge > 110 XS Double Cab |
17th Dec 2022 7:14pm |
For a while now my front heated windscreen has been a bit intermittent.
Bridging pins 4 and 8 of the timer relay got it working so it seemed to be a problem with the timer relay PRC6796. On closer inspection I found that the solder joint between one of the pins and the PCB had cracked and wasn’t making connection. After reflowing the solder joint the system came back to life so to prevent this happening again I epoxied the back of the pins for a bit of extra support Click image to enlarge Click image to enlarge > 110 XS Double Cab |
21st Jan 2023 5:50pm |
Fitted a pair of X-Trouser Door Strikers after a third tearage incident of a passengers trousers
27th Jan 2023 3:37pm |
Unfortunately not > 110 XS Double Cab
27th Jan 2023 5:10pm |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
Did you go for an ATB in the center diff?
Nothing on earth is going to stop that, my wife blames the Defender everytime. I'm tempted to charger her £1 every time so it goes into the new seat belt fund... Esp as I spent a fair amount on new ones for the last MOT. |
27th Jan 2023 5:24pm |
Nah, couldn't justify it for a road queen! > 110 XS Double Cab |
27th Jan 2023 5:57pm |
Ah fair, the money pit bites us all hard, I’ve been debating my options if I rebuild.
27th Jan 2023 10:16pm |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 322 |
Have you tried 8510403 A picture on here: https://www.defender2.net/forum/topic18250.html?view=next |
28th Jan 2023 1:29pm |
TexasRover Member Since: 24 Nov 2022 Location: Paris Posts: 1118 |
Thanks! they are only £12 put two in my cart for the next drop.
28th Jan 2023 4:54pm |
New brake shoes on ifor today. Nice straightforward job for a change!
The pad material had delaminated on all four shoes. The trailer was effectively unbraked so towing any weight was a bit sketchy! Click image to enlarge Click image to enlarge > 110 XS Double Cab |
28th Jan 2023 6:31pm |
Engine has been showing typical signs of a failing VCV recently - flat spot on acceleration, general laziness and lack of power.
It was no wonder when I removed the old VCV to find it in two parts! New genuine DENSO unit fitted and what a transformation, it's a pleasure to drive again!! Click image to enlarge Click image to enlarge Click image to enlarge > 110 XS Double Cab |
6th Feb 2023 2:32pm |
BrickBox Member Since: 05 Oct 2021 Location: Wales Posts: 857 |
How much was a genuine one? 2008 2.4 110 Utility Station Wagon XS.
6th Feb 2023 3:33pm |
£80 odd delivered from LR Parts - chose DENSO form the drop down https://www.lrparts.net/lr009837-fuel-vapo...ngine.html > 110 XS Double Cab
6th Feb 2023 3:44pm |
