Home > My Defender > hanks Double Cab
Page 18 of 22 <123 ... 171819 202122>
hank
The newly built Ashcroft LT230 arrived today so hoping to get it fitted Saturday.
 > 110 XS Double Cab
Post #974393 12th Dec 2022 1:40pm
hank
Swapped out the transfer box today so the old girl is back on road.
Wasn’t too bad, took about four or five hours with the help of my Dad. Couldn’t get diff lock initially but realised I’d managed to refit the linkage backwards - not even sure how that was possible!
Ashcroft output shaft still looking mint after all this time
 > 110 XS Double Cab
Post #975009 17th Dec 2022 7:14pm
hank
For a while now my front heated windscreen has been a bit intermittent.
Bridging pins 4 and 8 of the timer relay got it working so it seemed to be a problem with the timer relay PRC6796.
On closer inspection I found that the solder joint between one of the pins and the PCB had cracked and wasn’t making connection.
After reflowing the solder joint the system came back to life so to prevent this happening again I epoxied the back of the pins for a bit of extra support
 > 110 XS Double Cab
Post #979147 21st Jan 2023 5:50pm
hank
Fitted a pair of X-Trouser Door Strikers after a third tearage incident of a passengers trousers
 > 110 XS Double Cab
Post #980048 27th Jan 2023 3:37pm
TexasRover
Do they stop your wife from slamming the door shut with the seatbelt stuck in the lock?
My passenger side seatbelt is more worn than the driver side. Only on a defender..
Post #980051 27th Jan 2023 4:15pm
hank
Laughing Unfortunately not > 110 XS Double Cab
Post #980061 27th Jan 2023 5:10pm
kenzle8a
Did you go for an ATB in the center diff?
Nothing on earth is going to stop that, my wife blames the Defender everytime. I'm tempted to charger her £1 every time so it goes into the new seat belt fund... Esp as I spent a fair amount on new ones for the last MOT.
Post #980064 27th Jan 2023 5:24pm
hank
hank wrote:
I did consider it, but given the £1200 cost for an ashcroft LT230 plus the £500 I spent rebuilding it two and a half years ago I couldn't stomach the further £400 odd for an ATB - particularly as 99.99% of my driving is on road.
On the rare occasions I find myself in wheelspin/planet gears friction welding to cross pin conditions (snow or off road) I am happy to shift into diff lock.
ATB's in the axles perhaps in future, but open/locked diff in the transfer box is sufficient for my purposes
Nah, couldn't justify it for a road queen! > 110 XS Double Cab
Post #980074 27th Jan 2023 5:57pm
kenzle8a
Ah fair, the money pit bites us all hard, I’ve been debating my options if I rebuild.
Post #980117 27th Jan 2023 10:16pm
v8bob
United Kingdom 1998 Defender 90 300 Tdi HT Nato Green
Have you tried 8510403
A picture on here:
https://www.defender2.net/forum/topic18250.html?view=next
Post #980177 28th Jan 2023 1:29pm
TexasRover
Thanks! they are only £12 put two in my cart for the next drop.
Post #980188 28th Jan 2023 4:54pm
hank
New brake shoes on ifor today. Nice straightforward job for a change!
The pad material had delaminated on all four shoes. The trailer was effectively unbraked so towing any weight was a bit sketchy!
 > 110 XS Double Cab
Post #980200 28th Jan 2023 6:31pm
hank
Engine has been showing typical signs of a failing VCV recently - flat spot on acceleration, general laziness and lack of power.
It was no wonder when I removed the old VCV to find it in two parts!
New genuine DENSO unit fitted and what a transformation, it's a pleasure to drive again!!
 > 110 XS Double Cab
Post #981496 6th Feb 2023 2:32pm
BrickBox
How much was a genuine one? 2008 2.4 110 Utility Station Wagon XS.
Post #981501 6th Feb 2023 3:33pm
hank
£80 odd delivered from LR Parts - chose DENSO form the drop down https://www.lrparts.net/lr009837-fuel-vapo...ngine.html > 110 XS Double Cab
Post #981502 6th Feb 2023 3:44pm
