![]() | Home > Wheels & Tyres > 20mm Wheel Spacers |
Is it possible to fit 20mm Wheel Spacers to a Defender with alloy wheels, and if so does anyone know a supplier.
30mm Wheelspacers are easy to find but will bring the tyres out beyond the Wheel arch and I want to keep them within if posssible. ![]() |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 ![]() ![]() ![]() |
Rakeway engineering could probably make you a set
http://www.rakeway.com/ |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 ![]() ![]() ![]() |
I think the problem with 20mm spacers is theres not enough material to hold the stud
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1847 ![]() ![]() ![]() |
I had 30mm spacers with boost alloys on 265 mudders and they were just within the wheelarches, I still have them if you wanted to try them on for size before buying a set.
Thanks for all the posts. I think "Sonic3d" is probably correct regarding the thickness being required so that strength is not compromised. And thanks for the offer "ickle". I'll probably go for the 30mm ones, when I get around to fitting them.
Thanks All. ![]() |
