Home > Wheels & Tyres > 20mm Wheel Spacers |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 |
Is it possible to fit 20mm Wheel Spacers to a Defender with alloy wheels, and if so does anyone know a supplier.
30mm Wheelspacers are easy to find but will bring the tyres out beyond the Wheel arch and I want to keep them within if posssible. |
30th Jan 2011 2:01pm |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 |
Rakeway engineering could probably make you a set
http://www.rakeway.com/ |
30th Jan 2011 2:29pm |
Sonic3d Member Since: 28 Jan 2008 Location: Ross on Wye Posts: 1505 |
I think the problem with 20mm spacers is theres not enough material to hold the stud
30th Jan 2011 6:57pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1808 |
I had 30mm spacers with boost alloys on 265 mudders and they were just within the wheelarches, I still have them if you wanted to try them on for size before buying a set.
30th Jan 2011 7:54pm |
Thanks for all the posts. I think "Sonic3d" is probably correct regarding the thickness being required so that strength is not compromised. And thanks for the offer "ickle". I'll probably go for the 30mm ones, when I get around to fitting them.
Thanks All. |
31st Jan 2011 9:07am |
