Home > Technical > Why won't my transfer box rear seal stop leaking? |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
I think they're all incontinent.
4th Mar 2017 7:47am |
Froglaise Member Since: 24 Sep 2016 Location: left forum Posts: 212 |
Yes, but JLR must have realised those stick on incontinence pads would just fall off after a mile or so!
4th Mar 2017 7:57am |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
Is it leaking from the seal or wicking down the splines?
I found this after a quick search after remembering talk of a recall. http://www.defender2.net/forum/topic5697.html?highlight=p022 Cheers, Kyle. |
4th Mar 2017 8:38am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2244 |
What state is the drive flange seal land in because you don't say that you've replaced the drive flange and if previous seals have worn grooves on the sealing land then any replacement won't last long.
4th Mar 2017 10:10am |
v8bobber Member Since: 26 Aug 2012 Location: pembrokeshire Posts: 446 |
Mine was leaking when I bought it. It was a handy way of knocking the price down! It happens on the TDci because when they put that particular engine in, it ended up that the gearbox sits on the slant with the back end down.
The oil eventually runs down the splines because of the angle. I can't remember exactly what it is you use but it's some kind of locking compound between the splines on the shaft and flange. Some googling should find out what it is you need. Did mine a couple of years ago and hasn't leaked since |
4th Mar 2017 11:55am |
mowcop Member Since: 03 Jul 2009 Location: Staffs Posts: 108 |
I did fit a new drive flange one time but it still leaked!
I will seal the splines next time. I get that constant slight smell of hot gear oil as it must flick the odd drop onto the exhaust. |
4th Mar 2017 2:57pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10782 |
My transfer box gave up so a recon was put in and after 2 weeks the same happened to mine what has happened to yours, so i replaced the seal and the handbrake shoes and then after another 2 weeks the same happened again so went in again and changed the seal and the handbrake shoes and after another 2 weeks, guess what, yes it was doing the same thing, so by chance i was working close to my mechanic's place and popped in, the day was a very hot day and the oil was very warm, so we put her up on the ramp and we found the problem.... the oil was leaking between the seal and the transfer box casing, so they did a creative fix which stopped the oil coming out until another TB was at the workshop to change it over and once that was done, i have not had a leak again The firm that the TB came from where good as gold, did not argue or complain, they sent another TB with in a few days
Hope this helps you 1996 Golf Blue 300Tdi 110 Pick up. Keeper. Clayton. |
4th Mar 2017 11:22pm |
I know you should replace your handbrake shoes when they had contact with oil, but I clean them with degreaser a few times and then rub them with sandpaper and I put them back. Till now they never failed the MOT on working only once on adjustment. 2 minute fix and it was OK. Roel
5th Mar 2017 11:19am |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 |
Are you replacing the white felt washer that sits under the washer that holds the flange on? FRC2464 is the part number. 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
6th Mar 2017 1:24pm |
I thought that that washer was no longer used?
6th Mar 2017 8:31pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5850 |
My TC used to leak, no matter what, genuine parts, non gen parts sealant, no sealant still leaking.
Changed the TC (drastic) But after swapping out for a Disco one, I could inspect better and found some scratches on the inside were the seal sat. Now with the Disco one, all is well. (apart from towing, and long hills) 1999 Defender TD5 110 Regards John M0VAZ Econet Station 48 no clock |
6th Mar 2017 8:37pm |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 559 |
The felt washer is still used. Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
6th Mar 2017 10:47pm |
New shoes, seal and felt washer fitted.
Seal fitted with flange sealant and loctite on the splines, all aligned with the proper alignment tool. Fingers crossed |
18th Mar 2017 7:21am |
