Home > 130 > 90/110 rear wheel arch on 130
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
Before i get all button happy and click buy, would the Spat Bearmach wheel arch for a 90/110 fit the 130? Fronts is no brainer, the rear, well i am drawing blanks...I found an incomplete Matt set for cheap, and it doesnt have the holes on the outside like some of the aftermarket ones.
Let me know your thoughts
Post #598496 2nd Feb 2017 8:49am
RoadForce
Netherlands 2000 Defender 130 Td5 HCPU Coniston Green
I have 90/110 fronts on my rear arches, left goes right and right goes left (so the are on reversed). This is a common technique although some use the rear ones from a 90/110. I cut off the part that normally runs along the inside of the front wheelarches, then used a drill and 14mm rivets to mount them, using a heat gun to help them to follow the arch. Then, and this is optional, I trimmed them down using and angle grinder because I don't like them to be too wide (they sit wider because the HCPU tub is wider than the body).
Here's a pic
 Defender 130 HCPU Td5 MY2000
Post #598666 2nd Feb 2017 7:02pm
Naf
Thank you for the reply,
This is why i like forums, ppl are always so helpfull
Post #598755 3rd Feb 2017 5:08am
RoadForce
Glad to be of help!
I know there is a nice "guide" somewhere in a topic, a picture with lines and comments instructing you how to do it. If I find it, I will post a link. Defender 130 HCPU Td5 MY2000
Post #598762 3rd Feb 2017 7:04am
RoadForce
Here you go:
http://www.defender2.net/forum/post70950.h...9d73#70950 Defender 130 HCPU Td5 MY2000
Post #598793 3rd Feb 2017 11:22am
Naf
Thank you..
Its more of a rear fender mod more so than a front to rear fender mod, but the process is there...
Post #599220 5th Feb 2017 12:08pm
