![]() | Home > 130 > 90/110 rear wheel arch on 130 |
RoadForce Member Since: 17 Jul 2014 Location: Holland Posts: 342 ![]() ![]() ![]() |
I have 90/110 fronts on my rear arches, left goes right and right goes left (so the are on reversed). This is a common technique although some use the rear ones from a 90/110. I cut off the part that normally runs along the inside of the front wheelarches, then used a drill and 14mm rivets to mount them, using a heat gun to help them to follow the arch. Then, and this is optional, I trimmed them down using and angle grinder because I don't like them to be too wide (they sit wider because the HCPU tub is wider than the body).
Here's a pic ![]() Click image to enlarge Defender 130 HCPU Td5 MY2000 |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 ![]() ![]() ![]() |
Thank you for the reply,
This is why i like forums, ppl are always so helpfull |
Glad to be of help!
I know there is a nice "guide" somewhere in a topic, a picture with lines and comments instructing you how to do it. If I find it, I will post a link. Defender 130 HCPU Td5 MY2000 |
Here you go:
http://www.defender2.net/forum/post70950.h...9d73#70950 Defender 130 HCPU Td5 MY2000 |
Thank you..
Its more of a rear fender mod more so than a front to rear fender mod, but the process is there... |
