Home > Maintenance & Modifications > D44 winch bumper |
taffrican Member Since: 14 Jan 2011 Location: Living room Posts: 624 |
Those 4 bolts are more than enough, you'd be amazed how much they could take, I really wouldn't bother strengthening anywhere else, besides, if Devon 4x4 supply the bumper like that then that's the way it's supposed to be, they really know their stuff Optimists say the glass is half full..
Pessimists say the glass is half empty.. Engineers say the glass is twice the size it needs to be! |
17th Jan 2017 10:10am |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 |
I've seen people install M12 bolts. This means you'd have to tap the captive nuts to that size.. Solved the bowel problem, working on the consonants...
17th Jan 2017 6:26pm |
Mdm Member Since: 11 Sep 2013 Location: Sunny Lancashire Posts: 1625 |
we used to run d44 products on the comp cars as well as the road car.excelent quality gear
std mountings will be fine. if in doubt give them a call or email jake with your query as they offer good free advice |
17th Jan 2017 9:22pm |
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1763 |
8.8 M10 Bolts holding the bumper on.
A brief google suggests that they will take 3T plus in shear. I'm not a mechanical engineer, but I'd assume you have 4 bolts, so 8 bearing faces (top and bottom) allowing for 24T of Strength in the bolts. I suspect it would start pulling out of the bumper and chassis legs first! |
17th Jan 2017 9:58pm |
^^ they wont be under equal stress so 24t can only be thought of as an ideal. How much stress a single bolt goes under during a worst case scenario is the number you need to compare with the 3t number you looked up. That's a harder number to come by Solved the bowel problem, working on the consonants...
18th Jan 2017 2:04am |
