Home > Maintenance & Modifications > D44 winch bumper
countdecash
Ireland 1999 Defender 90 Td5 CSW Epsom Green
D44 winch bumper
Hi guys i've just bought a D44 winch bumper and it is a really solid piece of kit. The only thing i notice is that it has just the normal 2 bolts each side to mount it on the chassis. Will those 4 bolts take the strain of the winch when winching? Should i look at welding brackets to bolt in onto side of chassis as well?
Post #593782 17th Jan 2017 10:05am
taffrican
Wales 2002 Defender 90 Td5 HT Java Black
Those 4 bolts are more than enough, you'd be amazed how much they could take, I really wouldn't bother strengthening anywhere else, besides, if Devon 4x4 supply the bumper like that then that's the way it's supposed to be, they really know their stuff Thumbs Up Optimists say the glass is half full..
Pessimists say the glass is half empty..
Engineers say the glass is twice the size it needs to be!
Post #593783 17th Jan 2017 10:10am
agentmulder
Kuwait
I've seen people install M12 bolts. This means you'd have to tap the captive nuts to that size.. Solved the bowel problem, working on the consonants...
Post #593891 17th Jan 2017 6:26pm
Mdm
we used to run d44 products on the comp cars as well as the road car.excelent quality gear
std mountings will be fine.
if in doubt give them a call or email jake with your query as they offer good free advice
Post #593958 17th Jan 2017 9:22pm
miker
8.8 M10 Bolts holding the bumper on.
A brief google suggests that they will take 3T plus in shear. I'm not a mechanical engineer, but I'd assume you have 4 bolts, so 8 bearing faces (top and bottom) allowing for 24T of Strength in the bolts. I suspect it would start pulling out of the bumper and chassis legs first!
Post #593972 17th Jan 2017 9:58pm
agentmulder
Kuwait
^^ they wont be under equal stress so 24t can only be thought of as an ideal. How much stress a single bolt goes under during a worst case scenario is the number you need to compare with the 3t number you looked up. That's a harder number to come by Thumbs Up Solved the bowel problem, working on the consonants...
Post #594002 18th Jan 2017 2:04am
