Home > Maintenance & Modifications > 2x2 driving lights on the roof, picture and ideas wanted
dommel
Netherlands 2000 Defender 90 Td5 SW Corris Grey
When I bought my Defender, there was at the front a hole in the roof. Probably used for an extra antenna. We have made an water resist connector on it and the wiring via two buttons and two relais to the battery.
I've already a FirstFour lamp bar, not mounted yet, and thinking about what kind of pair lamps I should install. I like the look of four lamps and have the possibility to switch in pairs; like flood and spot.
I don't like big pancakes on my roof, even I want to have the possibility to take my ladders with me on the roof.
What lamps do you have on the roof. Please show me and please put an description like mark, type and halogen/LED.
Post #589633 3rd Jan 2017 12:37am
dommel
I was thinking of 2 x 2 Hella FF40; driving and fog beams.
The TF705 in LED of Terrafirma looks also nice.
What is better; 2 driving in middle and 2 fog at side or 4 the same and 2 at side more turned to the left/right?
Post #589663 3rd Jan 2017 10:28am
When I ran four lights on the roof of a Discovery many years ago, I found that two fogs on the outside and two spots in the middle gave the best compromise of light spread.
I think I had Hella Comet spots, which were very good, but the fogs were generic ones. Given that they were being used more as flood lights than as intended, they were good enough. They can be quite vulnerable, particularly if pushing through trees, so I'd steer clear of very expensive lights for that application. Darren
Post #589665 3rd Jan 2017 10:38am
stanley
Here are mine , all spots but give a decent amount of light
Post #589674 3rd Jan 2017 11:43am
VVS210
I guess the best option for maximum light coverage would be a pair of pencil beam spots in the middle set up to give a small central overlap at range & a pair of normal spots on the outside angled to overlap with the outer edge of the beam pattern from the pencils. Your standard headlamps would add to the coverage closer to the vehicle.
Not sure which lamp units to go with as I haven't bought any for a while & due to minor accident damage have just removed my bull bar & Hella Rallye 3000s. The roof rack & Hella Rallye 1000s got removed a few years ago after my local garage tried to drive the 90 into their workshop without realising there were clearance issues... Shocked Whistle
Post #589675 3rd Jan 2017 11:43am
GSLRO
United Kingdom 2002 Defender 110 Td5 CSW Chawton White
Not sure which make they are but think they are (land rover) Hella with low and high beam, the switch set up is with two separate 3 way switches:
Low (3 way switch): on independent - off - on with headlights dip beam
High (3 way switch): on independent - off - on with headlight high beam and/or flash Adventure isn't paved!
Post #590441 5th Jan 2017 6:54pm
VeeTee
Netherlands
Description here. Cheers, Vincent
MySite
Post #590460 5th Jan 2017 7:38pm
dommel
Thank you for you answers. I still haven't make a decision. New idea is to mount a spot LED bar in the middle and at the outside round LED floodlights.
I've measured the lamp bar; 12cm high and 34cm between the mounting points.
Post #595465 22nd Jan 2017 10:34pm
My 110, bringing up the rear, with Rigid Industries spots and spreads. So good, I've kept them for my next motor.
None blinding pic
Post #595466 22nd Jan 2017 10:39pm
dommel
Nice ride and even good looking lights.
I've searched them on www.verstralershop.nl
Now I doubt between these Rigid ones and the lights of Piaa.
In the meanwhile the new buttons arrived. I've a pre 2000 dashboard in my TD5. The bottons below the steering wheel will remove to the center. On the roof there is already a plug mounted and wirings via relays.
Post #595532 23rd Jan 2017 10:58am
geobloke
This is what I did to my 1992 D90.
These are Hella FF 200 lamps. Two on the outside are fogs and the two on the inside are pencil beams. This was a superb setup giving awesome distance and width. It took quite a while to find a set of lamps that would sit under the Hanibal rack and above the windscreen. Really miss this setup...
Post #595539 23rd Jan 2017 11:25am
dommel
Headlights of a Defender are 17cm, aren't they?
Then are lights between 8-12cm IMHO nice to see.
Halogen lamps with eventually LED bulbs are also an idea.
Post #595804 24th Jan 2017 8:46am
geobloke
They are 7" in diameter, which is around 17.8cm.
Post #595835 24th Jan 2017 10:48am
DuncanS
United Kingdom 2008 Defender 110 Puma 2.4 USW Santorini Black
These are the rigid ones I'd suggest going for if going down that route: http://www.rigidindustries.com/led-lighting/83351 North Cumbria Search and Rescue - Team Leader
Post #595989 24th Jan 2017 8:08pm
