Home > Puma (Tdci) > Oil smells of diesel. What to check? |
I thought that is how the oil service light came on on a puma. When the oil had a certain amount of diesel in it it needs changing. I think I read it somewhere and didn't dream it Ray
30th Dec 2016 6:27pm |
enfield_dinosaur Member Since: 14 Jun 2015 Location: Tertius orbis Posts: 120 |
Thanks! No oil service light yet - albeit I am not sure I have such an indicator, it's a 07 2.4 TDCi -
30th Dec 2016 6:41pm |
That's indeed so for the 2.2 TDCi, but not for the 2.4. The 2.2 gets diesel contamination due to the DPF recycling, the 2.4 does not have that.... feature. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
30th Dec 2016 7:21pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17443 |
To be honest if it is a faint smell I wouldn't worry about it, but I would keep a close eye on the oil level. If it goes up, then investigation is called for.
30th Dec 2016 7:35pm |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 |
Could be injector seals
30th Dec 2016 8:17pm |
Ah didn't realise it was different for the 2.4 Ray My build thread http://www.defender2.net/forum/topic17615.html |
30th Dec 2016 8:48pm |
I find it quite funny that such an oil service light exists
But it fits with the rest of the Defender. Injector seals might be it. Aren't they the same as the copper gaskets sealing the injector towards the fuel lines? I am having injector trouble anyway (cyl. 1+3 are knocking and are slightly out of tolerance), so everything will have to come out for four new injectors on Jan. 5th anyway... Have a good New Years Eve everyone! |
31st Dec 2016 5:07pm |
Jukathy Member Since: 25 Jan 2015 Location: Berlin Posts: 170 |
I think not. My service light simply corresponds with time and mileage. I click the service light away and leave oil as is. Light won't come up again before time or mileage are 'service-critical' once more. Hence quality is not the issue (in my case at least) |
31st Dec 2016 8:46pm |
