Home > Puma (Tdci) > Oil smells of diesel. What to check?
enfield_dinosaur
2007 Defender 110 Puma 2.4 SW Java Black
Hi folks!
Oh the glory of DIY oil changes! 30 minutes spent draining the oil. 3 hours spent cleaning the workshop.
As it turns out, the oil does not trickle, but rather jets out of the engine Shocked
But here’s my question: the old oil smells faintly of diesel.
I have a little time on my hands over the next few days, so what should I check? The copper gaskets have been replaced already. The coolant is uncontaminated.
Thanks!
e_d
Post #588744 30th Dec 2016 7:21pm
mk1collector
I thought that is how the oil service light came on on a puma. When the oil had a certain amount of diesel in it it needs changing. I think I read it somewhere and didn't dream it Rolling with laughter Ray
My build thread
Post #588747 30th Dec 2016 7:27pm
enfield_dinosaur
Thanks! No oil service light yet - albeit I am not sure I have such an indicator, it's a 07 2.4 TDCi -
Post #588755 30th Dec 2016 7:41pm
ericvv
That's indeed so for the 2.2 TDCi, but not for the 2.4.
The 2.2 gets diesel contamination due to the DPF recycling, the 2.4 does not have that.... feature. Laughing
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #588768 30th Dec 2016 8:21pm
To be honest if it is a faint smell I wouldn't worry about it, but I would keep a close eye on the oil level. If it goes up, then investigation is called for.
Post #588777 30th Dec 2016 8:35pm
mick
Could be injector seals
Post #588810 30th Dec 2016 9:17pm
mk1collector
Eric
Ah didn't realise it was different for the 2.4 Ray
My build thread
Post #588826 30th Dec 2016 9:48pm
enfield_dinosaur
I find it quite funny that such an oil service light exists Smile
But it fits with the rest of the Defender. Injector seals might be it. Aren't they the same as the copper gaskets sealing the injector towards the fuel lines?
I am having injector trouble anyway (cyl. 1+3 are knocking and are slightly out of tolerance), so everything will have to come out for four new injectors on Jan. 5th anyway...
Have a good New Years Eve everyone!
Post #588995 31st Dec 2016 6:07pm
Jukathy
2012 Defender 110 Puma 2.2 SW Keswick Green
I think not. My service light simply corresponds with time and mileage. I click the service light away and leave oil as is. Light won't come up again before time or mileage are 'service-critical' once more.
Hence quality is not the issue (in my case at least) Smile
Post #589087 31st Dec 2016 9:46pm
