Home > In Car Electronics > Easy wire rout from battery box to other underseat spare box |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
You should be able to run wires directly between them, out of the side of the battery box at the back, clipped to the join between the seat box and the rear tub and then into the side of the other under seat box. TD5s run the main power feed that way to the fuse box. http://www.yorkshireoffroadclub.net/
20th Dec 2016 10:32pm |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 388 |
I did this by running flexible conduit ( 25mm) between the two boxes and followed existing cables and pipes to make it all look neat. I drilled out each box and used the appropriate conduit gland/seal. 👍 2015 90 XS Santorini Black
27th Dec 2016 8:51pm |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 |
Yup, flexible conduit here too.
Used a step drill to get to size for the appropriate gland. Glands were electrical style that screw tight instead of those auto kind that just use their elasticity as is. Solved the bowel problem, working on the consonants... |
27th Dec 2016 11:56pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20583 |
Just be careful where you are drilling and what is behind though. KEEP CALM AND Drill ON
28th Dec 2016 12:28am |
