Home > In Car Electronics > Easy wire rout from battery box to other underseat spare box
big110
2014 Defender 110 Puma 2.2 SW Keswick Green
My batteries are under the drivers seat (left hand drive PUMA)...what's the best way to rout wires to the underseat cubby that's empty under the passenger seat?
Post #586641 20th Dec 2016 10:25pm
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
You should be able to run wires directly between them, out of the side of the battery box at the back, clipped to the join between the seat box and the rear tub and then into the side of the other under seat box. TD5s run the main power feed that way to the fuse box. http://www.yorkshireoffroadclub.net/
Post #586652 20th Dec 2016 11:32pm
Vitesse
I did this by running flexible conduit ( 25mm) between the two boxes and followed existing cables and pipes to make it all look neat. I drilled out each box and used the appropriate conduit gland/seal. 👍 2015 90 XS Santorini Black
Post #588037 27th Dec 2016 9:51pm
agentmulder
Kuwait
Yup, flexible conduit here too.
Used a step drill to get to size for the appropriate gland. Glands were electrical style that screw tight instead of those auto kind that just use their elasticity as is. Solved the bowel problem, working on the consonants...
Post #588069 28th Dec 2016 12:56am
Just be careful where you are drilling and what is behind though. Thumbs Up WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #588072 28th Dec 2016 1:28am
