Home > In Car Electronics > Cable to connect Nanocom to 1998 300TDi 10AS immobiliser?
ThatJCB
United Kingdom 1998 Defender 90 300 Tdi HT Epsom Green
Has anyone managed to get a Nanocom to programme a 10AS from a 300TDi Defender?
At the moment my Nanocom is only unlocked for a Discovery 2 but if I was sure I could also programme the 10AS on my Defender I would buy the extra licence.
As far as I can tell the pre-TD5 Defenders don't have an OBD connector. If I could wire up a suitable cable to the immobiliser, in theory I would be able to programme key fobs and turn on the central door lock feature.
Any help would be much appreciated.
Any other low cost option to configure the 10AS would also be of interest.
Thanks --
John C Brown
Discovery 2 TD5 2004 | Defender 300TDi 1998
Post #585028 14th Dec 2016 2:44pm
dorsetsmith
do you EGR fitted ? as this has an OBD socket for programming if you look at the below you will find drawing
not shore if nanocom can connect to 300 tdi 10AS immobiliser as it is not listed in there web sit
Post #585030 14th Dec 2016 2:51pm
ThatJCB
I'm not familiar enough with the 300TDi to know if it still has an EGR valve.
My Disco does not have the EGR.
I'm not sure if this is relevant because as far as I know the immobiliser does not affect the EGR operation nor would it affect how I connect to the 10AS immobiliser.
Regards --
John C Brown
Post #585036 14th Dec 2016 3:06pm
dorsetsmith
but also 10AS as far as i no is same one all the way to TD5 right up 2006
Post #585040 14th Dec 2016 3:28pm
dorsetsmith
also may be that Nanocom work with obd2 pin out the on diffracts but soft ware is diffracts Embarassed
Post #585047 14th Dec 2016 3:58pm
ThatJCB
So, if I had a TD5 wiring diag and follow the output from that pin to the OBD socket on a TD5 I might be able to work out my own cable.
Thanks --
John C Brown
Post #585048 14th Dec 2016 4:00pm
bankz5152
I highly doubt the Nanocom would be able to connect properly, but for the cost of an extra licence you can send your 10AS off to be properly programmed, just the hassle of removing it.
Post #609614 15th Mar 2017 12:40pm
ThatJCB
Thanks for the reply.
I paid for the licence and tried it out. Works fine as far as I can tell. All the options appear but I haven't tried to change any yet.
Uses the standard blue cable I have for the TD5 Discovery. I worried unnecessarily, no modification needed.
Thanks --
John C Brown
Post #609635 15th Mar 2017 1:49pm
bankz5152
Oh wow, thats pretty awesome! Nice one.
Post #609639 15th Mar 2017 2:15pm
