Home > In Car Electronics > Cable to connect Nanocom to 1998 300TDi 10AS immobiliser? |
do you EGR fitted ? as this has an OBD socket for programming if you look at the below you will find drawing
Click image to enlarge not shore if nanocom can connect to 300 tdi 10AS immobiliser as it is not listed in there web sit Click image to enlarge Last edited by dorsetsmith on 14th Dec 2016 4:14pm. Edited 2 times in total |
14th Dec 2016 2:51pm |
ThatJCB Member Since: 13 Dec 2016 Location: Essex Posts: 4 |
I'm not familiar enough with the 300TDi to know if it still has an EGR valve.
My Disco does not have the EGR. I'm not sure if this is relevant because as far as I know the immobiliser does not affect the EGR operation nor would it affect how I connect to the 10AS immobiliser. Regards -- John C Brown Discovery 2 TD5 2004 | Defender 300TDi 1998 |
14th Dec 2016 3:06pm |
but also 10AS as far as i no is same one all the way to TD5 right up 2006
14th Dec 2016 3:28pm |
also may be that Nanocom work with obd2 pin out the on diffracts but soft ware is diffracts
14th Dec 2016 3:58pm |
So, if I had a TD5 wiring diag and follow the output from that pin to the OBD socket on a TD5 I might be able to work out my own cable.
Thanks -- John C Brown Discovery 2 TD5 2004 | Defender 300TDi 1998 |
14th Dec 2016 4:00pm |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2169 |
I highly doubt the Nanocom would be able to connect properly, but for the cost of an extra licence you can send your 10AS off to be properly programmed, just the hassle of removing it.
15th Mar 2017 12:40pm |
Thanks for the reply.
I paid for the licence and tried it out. Works fine as far as I can tell. All the options appear but I haven't tried to change any yet. Uses the standard blue cable I have for the TD5 Discovery. I worried unnecessarily, no modification needed. Thanks -- John C Brown Discovery 2 TD5 2004 | Defender 300TDi 1998 |
15th Mar 2017 1:49pm |
Oh wow, thats pretty awesome! Nice one.
15th Mar 2017 2:15pm |
