Home > 130 > Upgrades
Page 3 of 8 <12345678>
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
The strip down started yesterday
Talked with yrm for s/s bolt kit, doors and rear cross member on route from lrparts.
Upgraded brakes and engine upgrades are prepped and ready.
Waitin on diff locker, axle overhaul kits, and when i have time transfer and gear box overhauls
Post #642787 9th Aug 2017 4:58pm
bankz5152
Looking good!!
Ill follow closely, Ive been contemplating moderately porting my head too, just not sure if its worth the agro!
Post #642820 9th Aug 2017 6:49pm
KGH
United States 2013 Defender 110 Puma 2.2 HT Keswick Green
Nice work there. Are you going to be able to dyno the truck after engine mods?
I like the porting and controlled turbo ideas!
My 130 is still in progress at Foley's. 2013 110 - Keswick Green
1995 ExRAF 110 Utility
1986 127 HCPU
1985 110 PU
2012 Disco4
Post #643088 11th Aug 2017 1:11am
Naf
I have the opportunity to put the truck on the Dyno and I should be able to also log the information where I will get the EGT the boost and RPM, so then I'm also able to tweak the tune where all my parameters should be in check
Post #643653 13th Aug 2017 5:05pm
Naf
I wiuld love to get some recaros into my defender, but due to other restos my wonderful buy anything budget dwindled to a i think i can afford this
https://www.ebay.co.uk/itm/172786079355
Saw it on TirsbaekTV on youtube, only downside is i have to remove the whole seat to access the batt or ecu...
Post #645231 20th Aug 2017 4:19pm
Naf
Latest additions to my upgrade list
Roamdrive overdrive
62 ltr front runner aux fuel tank
Now still waitin on safety devices to deliver my roll cage, its been 6 weeks, and every week its always at the end of that current week.
Bad customer service for sure from them...
Post #646083 24th Aug 2017 1:54pm
Naf
Found some Recaro seats on Ebay...woohoo
They are not exactly for a Defender, but affordable. I am waiting for UPS to pick them up for me, so i may start to see what could be done to make them near perfect additions for my ride.
I also was given a free center consol seat combo that should fit with a little fabrication work done to the lower bracket.
Pix to follow delivery of parts.
My bulkhead repairs will start next week once my parcel clears customs.
I also fixed the rear box where the a-frame connects to. Had a few holes and we welded them shut with 3mm pcs.
Post #651194 19th Sep 2017 5:17am
familymad
It's good to see a 130 getting some love!! 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #651211 19th Sep 2017 7:27am
Naf
had a serious push in the past week
Big thank you to LRParts.net, YRM, and flebay...
Post #653669 29th Sep 2017 3:45pm
Naf
My attempt to swappin out the rear xmember...
Will add more 3mm plates for structrual support.
Post #654658 3rd Oct 2017 6:57pm
Naf
Its been a while, and we are makin some nice strides
Chassis has been painted and then coated with bedliner
The body parts were primed and painted
and now i am waitin on a few axle upgrades, as well as diff so i may create my rollin chassis and then assemble.
As a bonus, i wish i googled before i went balls to the wall with Alive. I found a Billet cartridge from turbo rebuild limited for around 200gbp.
https://www.turborebuild.co.uk/webshop/pro...ridge.html
I may just buy the cartridge, and install it on my 10p engine, then over the summer, swap the 10p for my ported 15p with hybrid turbo and see what it brings to the table.
Just need to find a stage 1 chip for my MSB ecu...
Post #661116 1st Nov 2017 8:53am
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Fantastic work so far Thumbs Up looking forward to the finished article and seeing the new found power. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #661131 1st Nov 2017 10:21am
Naf
I am tryin to find the MSB chip so i dont have to spend 250GBP with some companies...
The disco chip is goin for 60gbp, but it seems i am not able to use it in my Defender...
Post #661140 1st Nov 2017 12:16pm
Coatesyyy
Keeping an eye on this thread, very interesting Thumbs Up
Post #661142 1st Nov 2017 12:34pm
JOW240725
Wow great work! Thumbs Up James
Instagram @suffolk_rovers
Post #661151 1st Nov 2017 1:32pm
