Home > 130 > Upgrades |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2173 |
Looking good!!
Ill follow closely, Ive been contemplating moderately porting my head too, just not sure if its worth the agro! |
9th Aug 2017 6:49pm |
KGH Member Since: 01 Feb 2015 Location: Florida Keys Posts: 61 |
Nice work there. Are you going to be able to dyno the truck after engine mods?
I like the porting and controlled turbo ideas! My 130 is still in progress at Foley's. 2013 110 - Keswick Green 1995 ExRAF 110 Utility 1986 127 HCPU 1985 110 PU 2012 Disco4 |
11th Aug 2017 1:11am |
Naf Member Since: 07 Dec 2016 Location: Sandbox Posts: 412 |
I have the opportunity to put the truck on the Dyno and I should be able to also log the information where I will get the EGT the boost and RPM, so then I'm also able to tweak the tune where all my parameters should be in check
13th Aug 2017 5:05pm |
I wiuld love to get some recaros into my defender, but due to other restos my wonderful buy anything budget dwindled to a i think i can afford this
https://www.ebay.co.uk/itm/172786079355 Saw it on TirsbaekTV on youtube, only downside is i have to remove the whole seat to access the batt or ecu... |
20th Aug 2017 4:19pm |
Latest additions to my upgrade list
Roamdrive overdrive 62 ltr front runner aux fuel tank Now still waitin on safety devices to deliver my roll cage, its been 6 weeks, and every week its always at the end of that current week. Bad customer service for sure from them... |
24th Aug 2017 1:54pm |
Found some Recaro seats on Ebay...woohoo
They are not exactly for a Defender, but affordable. I am waiting for UPS to pick them up for me, so i may start to see what could be done to make them near perfect additions for my ride. I also was given a free center consol seat combo that should fit with a little fabrication work done to the lower bracket. Pix to follow delivery of parts. My bulkhead repairs will start next week once my parcel clears customs. I also fixed the rear box where the a-frame connects to. Had a few holes and we welded them shut with 3mm pcs. |
19th Sep 2017 5:17am |
familymad Member Since: 13 Dec 2011 Location: Bucks Posts: 3481 |
It's good to see a 130 getting some love!! 1951 80" S1 2.0
19th Sep 2017 7:27am |
had a serious push in the past week
Big thank you to LRParts.net, YRM, and flebay... Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
29th Sep 2017 3:45pm |
Click image to enlarge My attempt to swappin out the rear xmember... Will add more 3mm plates for structrual support. |
3rd Oct 2017 6:57pm |
Its been a while, and we are makin some nice strides
Chassis has been painted and then coated with bedliner The body parts were primed and painted and now i am waitin on a few axle upgrades, as well as diff so i may create my rollin chassis and then assemble. Click image to enlarge As a bonus, i wish i googled before i went balls to the wall with Alive. I found a Billet cartridge from turbo rebuild limited for around 200gbp. https://www.turborebuild.co.uk/webshop/pro...ridge.html I may just buy the cartridge, and install it on my 10p engine, then over the summer, swap the 10p for my ported 15p with hybrid turbo and see what it brings to the table. Just need to find a stage 1 chip for my MSB ecu... |
1st Nov 2017 8:53am |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Fantastic work so far looking forward to the finished article and seeing the new found power. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
1st Nov 2017 10:21am |
I am tryin to find the MSB chip so i dont have to spend 250GBP with some companies...
The disco chip is goin for 60gbp, but it seems i am not able to use it in my Defender... |
1st Nov 2017 12:16pm |
Coatesyyy Member Since: 07 Sep 2017 Location: Knutsford Posts: 423 |
Keeping an eye on this thread, very interesting
1st Nov 2017 12:34pm |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7906 |
Wow great work! James
1st Nov 2017 1:32pm |
