Home > 130 > Upgrades
Page 2 of 8 <12345678>
You have to wonder if one of the reasons that the TDCi Defender eats drivelines when compared to the TD5 is because of the change from DMF to SMF. There again it may be down to the greatly increased torque and difference engine characteristics ... or build and material quality ... or a combination of all of these.
But there must be a reason for it.
Post #632465 20th Jun 2017 3:13pm
Naf
Kuwait 2000 Defender 130 Td5 HCPU Nato Green No Canopy
My v8 caddy came with a heavy confortable flywheel which i swapped it for a single simple mass flywheel. It pumps out more power than my defender will ever and no issues.
The idea of dual mass fw is sound, but the added weight is useless. We are not drivin lil ms daisy, so "comfort" really isnt nexessary.
If you look at our setup we have 5 cyl that means in every two revolutions there is an ignition cycle every 144 degrees vs every 180 like in 4 cyl engines.
The gear chatter can be solved with some thicker synthtic oil.
I will be doin a rebuild on the gearbox, i feel there could be slight misalignment on the gears.
Post #632475 20th Jun 2017 5:06pm
Naf
Makin progress, we matched the intake runners to the gasket, later we will do the same for the exhaust side and intake manifold...
Post #632801 22nd Jun 2017 8:36am
Naf
Before
After a lil porting
Cant wait to see what this gives me on the road...
Post #634402 29th Jun 2017 2:34pm
Naf
Head is all done..
So now i am thinkin of doin a 3" down pipe through a 3" muffler than to the rear where it will go through a horizontal muffler and exit through two 2.5" outlets...
Should give me the look of a petrol app but in desiel
Post #635576 4th Jul 2017 5:16pm
JOW240725
Can't wait to see this develop! Please post some photos when you can, before and after mods! Thumbs Up James
Instagram @suffolk_rovers
Post #635578 4th Jul 2017 5:22pm
Naf
My lil engine is almost finished in the assembly shop.
Missing some bolts, studs, oil cooler o-rings and others... Normally you have extra, but my builds are not like that...
After which it will go off to paint, and get a nice black coat of paint.
I placed a rather high $ order with LR Parts. But i did save on shipping, and on the inner roll cage like i have been looking for. Sometimes its pays to shop around. The international dealer was overcharging me by 200 euro on the item and more on on shipping.
I also scored a 33mm front anti roll bar. Just need to find a 28mm rear and all the needed parts to get me rolling forward.
Its going to be on of my best rebuilds.
If only i could find a way to get the VATs back on all my ebay purchases, i would have more money for my habit...
After this build i am planning to bring back to life an old two door Yukon. But i cant decide if i want to run a 6.2ltr with LS7 heads or 6.6ltr with truck intake... Either way it will be a fast truck, and it will stand out from everything that came before it...
Post #635746 5th Jul 2017 11:32am
JOW240725
Sounds like quite a project! Thumbs Up Just want to see some photos!
Interesting to see have a bigger ARB on the front to the rear? I always thought the heavier roll bar was better on the back? James
Post #635776 5th Jul 2017 3:19pm
Naf
On all my rides, the front is always bigger than on the rear.
My Tahoe, CTS-V, and Yukon all had either 1/4" or 3/8" larger fronts than rear. But those are petrol engines, in "heavy" chassis configurations. To many variables
So, i googled a little, and found there is a way to control a VNT turbo on the TD5. there are two types, Vacuum controlled and Electronic.
Am in talks with tuning Diesels to see if i may get the turbo GTB2260V with electronic actuator to work on my ride. This aught to give me the bottom end kick, and top end power without over spooling. Should have done this before tossin money to Alive for their hybrid turbo.
Pictures will flow in next wheel, with before and after pix of each mod...
Post #635894 6th Jul 2017 7:33am
Naf
You know idle hands lead to devilish ideas.
I noticed the inlet to the intake manifold is 2.5", but all my turbo hoses and ic are 2"...
Bigger tubes less boost more flow, small tubes more boost less flow...
I feel if i upgrade the tubing after the turbo to 2.5" i should surely gain some more power. Especially after my airbox mod...
Will keep you all posted to my progress.
Post #639168 23rd Jul 2017 3:17pm
Naf
I am waiting on a couple sea shipments from LRparts.
Ordered the Safety device inner roll bar, full set of doors, and seals for the rest of the cab.
My inner doors are shot, my cross member is shot, and i just discovered rust in my bulkhead right under the heater box.
Happy days
So my first step is to add Aircon, as its 49+ on any given hellious day here.
I tore the dash apart, and we are going to yank the heater/blower box off
I am lookin to redesign the HVAC box using Disco 2 heater and evap parts. The main challenge is gettin the air to blow onto our face and not the windshield nor foot wells.
I ordered a Disco 1 ac control unit, with AC button. The guy didnt give me a break on the price even though Best offer was available. The idea is simple, the cutrrent setup uses cables and what nots, i will mimic that with the addition of on/off button for the ac that also is connected to the heater solenoid. This way when the AC is on the heater is off. and if i turn off the ac i am able to dial in the amount of heat i want.
Challenge is getting the defrost vents to close givin me facial air.
Did i mention i have rust? What am i to expect, she is 17yrs old from germany
Post #641408 2nd Aug 2017 2:35pm
JOW240725
49+°C!!! How do you do anything! I would just melt physically and mentally! Do you have an air-conditioned garage?!?! Shocked James
Post #641431 2nd Aug 2017 4:14pm
Naf
We have swamp coolers, so the dry heat is broken slightly.
Lately its been hotter, i swear its hitting 55+ for when i get home at 5pm after 120kph speeds my car temp is reading 50c.
ok, i swear i searched but where may i find a complete Stainless Bolt kit for my Defender?
I found bolts from UK suppliers on Ebay, but they are partial kits, i want the whole car so i dont suffer from stuck bolts.
Yanked the rear tub off for repair, and will start on the cab, but i have to admit, its a PITA...
Post #642574 8th Aug 2017 1:03pm
bankz5152
Looking good so far!
Just wondering if the porting is worth doing? What kind of gains are you expecting?
Post #642721 9th Aug 2017 9:48am
Naf
I am hopin 30-40 more in both. Plus when i slap on the vnt/twin turbo kits i have, i want the most it can give me and not blow up...
Post #642786 9th Aug 2017 4:54pm
