Home > My Defender > Proctas Defender 300TDI
Page 18 of 54 <123 ... 171819 ... 525354>
Procta
never heard of him pickles, I did a bit of research though, and he might have been james nash's engineer when he was in 888. He won the independent championship in the btcc in 2011 when Honda and matt neal took the full title. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #635839 5th Jul 2017 8:31pm
Procta
Also tonight there, some more stuff on order from Ebay, Gearbox mounts, a decat pipe, a number plate light, fan belt with tensioner, ( more info on that to come)
I did toy with the idea of buying my disc setup upgrade, but id rather do some more research on the rear side of things 1st as well as replacement hoses too. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #635840 5th Jul 2017 8:34pm
Profyaffle
What will you be doing with the brakes then?... 1993 200Tdi Defender 90
Post #635844 5th Jul 2017 8:45pm
Procta
I will be switching them to vented at the front, and upgrade the rears, I do have a problem somewhere across the board. So i might as well just upgrade while i have the option to do so. With me doing mainly motorway miles i want the system up to scratch. The A19 what i go on, is wacky races at times! So i need the stopping power, Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #635847 5th Jul 2017 8:49pm
Profyaffle
Good luck with that... I shall await further updates on it and the rest of your improvements.. Thumbs Up 1993 200Tdi Defender 90
Post #635848 5th Jul 2017 8:53pm
grafty99
I switched to vented front and 110 rears on mine. Made a nice improvement in stopping power Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #635852 5th Jul 2017 9:11pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
Sounds like you're getting ontop of it mate Thumbs Up 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #635861 5th Jul 2017 9:32pm
Pickles
Could be, I've heard him speak of Matt Neal.
Alex is currently with the Mobil 1 HSV Racing Team.
Pickles.
Post #635868 5th Jul 2017 10:02pm
Procta
what is the difference with the 110 setup vs the 90 rear wise. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #635873 6th Jul 2017 5:03am
Procta
yeah since I got the mot out of the way, been very expensive that was. Lost 450 on welding which was only worth about a 100 Evil or Very Mad Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #635874 6th Jul 2017 5:06am
Procta
Pickles.
Matt neal has been in the btcc for nearly 30 years, he has worked his way up from an independent team to a works drive. won the championship 3 times. But I think he has lost his spark now, your friend might have even worked with him too at some point. Some engineers do jump around. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #635875 6th Jul 2017 5:09am
grafty99
110 rear brakes are very slightly larger in diameter but the main difference is that the caliper is larger and has a larger piston for better braking on the rear.
The good thing is that it's a bolt on conversion and even with the extra power at the rear, the fronts still lock up before the rear. So it's still a stable and safe braking upgrade Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #635883 6th Jul 2017 6:22am
Rusty380
Nice progression, amazing how some of the small details make a big difference!
Post #635892 6th Jul 2017 7:27am
Procta
thanks for that grafty, another Ebay search and an item watched Smile Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #636051 6th Jul 2017 8:39pm
Procta
yeah the little things make the difference, which you will see when you add those touches to yours.
My dad isn't keen, he is more original, me I have gone for the more lux side of things, XS spec. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #636055 6th Jul 2017 8:40pm
