Home > Technical > Weird scangauge issue |
I would check the Scangauge and vehicle OBD connectors to make sure there are no bent/pushed back pins or sockets! The best time to clear codes is to do it immediately after turning the ignition off and then back on to the first position again (within the timescale of the Scangauge shutting down period)! If you have a second vehicle try the Scangauge on that!
With regards to the remaining symptoms you describe having downloaded 97 pages of fault codes from Dgardel's site myselfi and if your Scangauge is reading codes you should be able to read them to clarify what's wrong!!! The codes from the fault will be stored in your ECU. Post the codes up here or 'pm' Dgardel or download them yourself and all will hopefully be explained! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
13th Jan 2011 2:39pm |
tmcwhirter Member Since: 02 Dec 2010 Location: UK Posts: 23 |
Cheers - will have a fiddle with the plug and try again with the timing you suggest.
Thing is though, after losing power/electrics/batt warning light and then going back to normal there were no fault codes. Only one registering is the MAF sensor which was there before. This is why it stumped me! |
13th Jan 2011 3:03pm |
Also baffles me too! If it was a genuine fault one would expect some codes I would have thought? If you go through life with your head in the sand....all people will see is an ar5e!!
13th Jan 2011 5:25pm |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 |
lol ! I had excactly the same problem with a Turbogauge!
http://www.youtube.com/watch?v=72UgznoTDms just remove OBD plug and wait 1 min for the ECU to go to sleep than start without! my OBD reader doesnt work if itīs freezing -4c I always take it inside on cold days Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
14th Jan 2011 5:09pm |
Sorted now. Managed to clear codes using K9F's advice. Limp home issue hasn't re-occured so all good.
17th Jan 2011 11:31am |
Excellent news! Glad you're sorted! If you go through life with your head in the sand....all people will see is an ar5e!!
17th Jan 2011 4:58pm |
