Is there a common failure on the wiring harness & any premptive steps that can be taken?
13th Dec 2016 7:33pm
ian series 1
Just check the loom from actuator and follow it around the engine.
Unclip the loom, so you can check the underside for rubbing.
The loom on these engines are installed incredibly tight in places.
If you slacken them off, you can wrap some rubber tape or similar to prevent it rubbing.
The worse point is the fat part of the loom that runs across the front at the top of the engine.80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
13th Dec 2016 7:46pm
Fos_landy
this was the issue with mine - once all the masking tape had been unwound...
always get the garage to have a look. lesson learned!Defender 90 Puma 2.4
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
