Home > Technical > What voltage does the interior light run at? |
danridge Member Since: 28 May 2013 Location: Bath Posts: 438 |
Many thanks.
7th Nov 2016 6:38pm |
Full vehicle voltage, so nominally 12v but closer to 14v when the engine is running. Darren
7th Nov 2016 6:49pm |
Thanks guys
7th Nov 2016 7:57pm |
Alien Member Since: 18 Jan 2015 Location: Bacchus Marsh Posts: 230 |
If your chasing a problem such as it being dull on opening the doors but OK when switched manually have a look at the door switches for bad earth connections. Cheers,
Kyle. |
7th Nov 2016 10:40pm |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
The quality of the door contacts shouldn't make any difference on a TD5 because the interior lighting is controlled by the 10AS alarm doofer.
They have a permanent 12V feed to one side of the bulb then the switch selects whether the other side is connected to nothing (off), 0V (on) or the 10AS (auto). |
7th Nov 2016 10:59pm |
