Home > Technical > What voltage does the interior light run at?
danridge
United Kingdom 2004 Defender 90 Td5 XS CSW Java Black
Many thanks.
Post #576097 7th Nov 2016 7:38pm
Full vehicle voltage, so nominally 12v but closer to 14v when the engine is running. Darren
Post #576099 7th Nov 2016 7:49pm
As above, approx 12.2v at rest & 14.2v with alternator charging current. WeWillWinπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #576101 7th Nov 2016 8:07pm
danridge
Thanks guys
Post #576107 7th Nov 2016 8:57pm
Alien
Australia
If your chasing a problem such as it being dull on opening the doors but OK when switched manually have a look at the door switches for bad earth connections. Cheers,
Kyle.
Post #576147 7th Nov 2016 11:40pm
Cupboard
The quality of the door contacts shouldn't make any difference on a TD5 because the interior lighting is controlled by the 10AS alarm doofer.
They have a permanent 12V feed to one side of the bulb then the switch selects whether the other side is connected to nothing (off), 0V (on) or the 10AS (auto).
Post #576152 7th Nov 2016 11:59pm
