![]() | Home > For Sale & Wanted > [For Sale] Switch holders.... |
benspray Member Since: 31 Jul 2014 Location: Norfolk Posts: 165 ![]() ![]() ![]() |
Hi are these still available (I'll need a double or triple not 100% sure yet)
Cheers Ben |
mikeh Member Since: 05 Feb 2015 Location: South Coast Posts: 28 ![]() ![]() ![]() |
Did anyone confirm if the 3 slot fits into the side panel area? |
roamfree Member Since: 19 Jan 2022 Location: Northern Germany Posts: 24 ![]() ![]() ![]() |
Hey Andy, would you still have some of the Triple ones available? Cheers, Felix |
Lukas69 Member Since: 12 Jun 2022 Location: Florence Posts: 1 ![]() ![]() ![]() |
Hallo.... you still have thise fantastic switch panels? I necess the big hazard one, and a double normal. Waiting for answer, Regards lukas |
Pajak Member Since: 17 Nov 2022 Location: AG Posts: 1 ![]() ![]() ![]() |
Hello
Are these brackets still available? I am interested in one for three switches. Best regards, Pajak |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1261 ![]() ![]() |
the same switches were used in the Freelander 1
Only available bank of switches was of 4 https://www.ebay.co.uk/itm/374354843160?ha...R66D-PiQYQ also available in black |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 ![]() ![]() ![]() |
Is a 6 available if these are being printed?
3x3 over and under… |
gumdrop Member Since: 16 Jan 2010 Location: North Yorkshire Posts: 126 ![]() ![]() |
Hi Andy,
I tried contacting you by email - do you have any of the single holders left? I too would be interested in a custom switch holder for 5 switches. Cheers, Simon Cheers Simon ------------------------- 50th D90 - my toy! Freelander SE Td4 3 door - local run around 1958 Series 1- Rag top! |
andyrad Member Since: 26 Sep 2018 Location: somerset Posts: 14 ![]() ![]() ![]() |
Hi Andy,
can you do a custom bezel? im looking for a 3 way bezel, elec windows on the outside and a vertical hazards switch (RR classic) in the middle - any chance of this? Thanks Andy |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2942 ![]() ![]() |
Hi Andy,
Yes I could although I would need the hazard switch or is it just the same as a TDCI switch? Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
It looks the same as the tdci, 27mm x 37mm but in portrait.
this is what I'm trying to do, picture attached (I Hope) but not sure how wide your bezel will be. the gap between the hazard switch and the window switch is 17mm and the gap from the window switch to the USB/12v is only 12mm. I could use the smaller Discovery 2 hazard switch (which I think looks a bit neater) - but I need to add in extra relays to make this switch work. I can send you the hazard switch if it helps Thanks Andy ![]() Click image to enlarge ![]() Click image to enlarge |
Can you give a basic drawing of that with the dims across the surround and switches? I can model it up here quickly and send you some images. Andy
sorry just seen you added some dims Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 566 ![]() ![]() ![]() |
Hi Andy,
Similar question to Yannis, is a 3 over 3 panel possible? Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
