Home > For Sale & Wanted > [For Sale] Switch holders.... |
benspray Member Since: 30 Jul 2014 Location: Norfolk Posts: 162 |
Hi are these still available (I'll need a double or triple not 100% sure yet)
Cheers Ben |
29th Nov 2021 10:20pm |
mikeh Member Since: 05 Feb 2015 Location: South Coast Posts: 28 |
Did anyone confirm if the 3 slot fits into the side panel area? |
28th Dec 2021 6:21pm |
roamfree Member Since: 19 Jan 2022 Location: Northern Germany Posts: 16 |
Hey Andy, would you still have some of the Triple ones available? Cheers, Felix |
9th Mar 2022 6:20pm |
Lukas69 Member Since: 12 Jun 2022 Location: Florence Posts: 1 |
Hallo.... you still have thise fantastic switch panels? I necess the big hazard one, and a double normal. Waiting for answer, Regards lukas |
12th Jun 2022 3:55pm |
Pajak Member Since: 17 Nov 2022 Location: AG Posts: 1 |
Hello
Are these brackets still available? I am interested in one for three switches. Best regards, Pajak |
17th Nov 2022 9:25pm |
LR Nuts Member Since: 10 Aug 2022 Location: UK Posts: 1119 |
the same switches were used in the Freelander 1
Only available bank of switches was of 4 https://www.ebay.co.uk/itm/374354843160?ha...R66D-PiQYQ also available in black |
17th Nov 2022 9:52pm |
Yannis Member Since: 02 Feb 2015 Location: Oxfordshire / Milan Posts: 408 |
Is a 6 available if these are being printed?
3x3 over and under… |
13th Dec 2022 10:44pm |
gumdrop Member Since: 16 Jan 2010 Location: North Yorkshire Posts: 125 |
Hi Andy,
I tried contacting you by email - do you have any of the single holders left? I too would be interested in a custom switch holder for 5 switches. Cheers, Simon Cheers Simon ------------------------- 50th D90 - my toy! Freelander SE Td4 3 door - local run around 1958 Series 1- Rag top! |
15th Dec 2022 10:37am |
andyrad Member Since: 26 Sep 2018 Location: somerset Posts: 14 |
Hi Andy,
can you do a custom bezel? im looking for a 3 way bezel, elec windows on the outside and a vertical hazards switch (RR classic) in the middle - any chance of this? Thanks Andy |
5th Nov 2023 10:27pm |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2893 |
Hi Andy,
Yes I could although I would need the hazard switch or is it just the same as a TDCI switch? Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
9th Nov 2023 9:00am |
It looks the same as the tdci, 27mm x 37mm but in portrait.
this is what I'm trying to do, picture attached (I Hope) but not sure how wide your bezel will be. the gap between the hazard switch and the window switch is 17mm and the gap from the window switch to the USB/12v is only 12mm. I could use the smaller Discovery 2 hazard switch (which I think looks a bit neater) - but I need to add in extra relays to make this switch work. I can send you the hazard switch if it helps Thanks Andy Click image to enlarge Click image to enlarge |
9th Nov 2023 11:33am |
Can you give a basic drawing of that with the dims across the surround and switches? I can model it up here quickly and send you some images. Andy
10th Nov 2023 10:10am |
sorry just seen you added some dims Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
10th Nov 2023 10:35am |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 558 |
Hi Andy,
Similar question to Yannis, is a 3 over 3 panel possible? Cheers Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
10th Nov 2023 2:08pm |
