Home > For Sale & Wanted > [For Sale] Switch holders....
Page 9 of 10 <12345678910>
benspray
United Kingdom 2006 Defender 130 Td5 HCPU Chawton White
Hi are these still available (I'll need a double or triple not 100% sure yet)
Ben
Post #931772 29th Nov 2021 10:20pm
KISSMYAURA
United Kingdom 2003 Defender 90 2.5 TD SW Epsom Green
Re: [For Sale] Switch holders....
mcma1 wrote:
Puma Switch Holders For Sale...
Triple �12
Double �10
Single �8
Postage �3.50 UK
Andy you still have these avaialable?
Post #932226 2nd Dec 2021 6:17pm
mikeh
United Kingdom 2015 Defender 90 Puma 2.2 SW Corris Grey
Falcon_spb wrote:
Actually I’m curious if it will fit properly this place
Did anyone confirm if the 3 slot fits into the side panel area?
Post #935431 28th Dec 2021 6:21pm
roamfree
Germany 2009 Defender 110 Puma 2.4 SW Santorini Black
Triple �12
Double �10
Single �8
Postage �3.50 UK
Hey Andy, would you still have some of the Triple ones available?
Cheers,
Felix
Post #945188 9th Mar 2022 6:20pm
Lukas69
Italy 2008 Defender 110 Puma 2.4 SW Tonga Green
mcma1 wrote:
Yes sure do
Hallo.... you still have thise fantastic switch panels?
I necess the big hazard one, and a double normal.
Waiting for answer,
Regards lukas
Post #955293 12th Jun 2022 3:55pm
Pajak
Switzerland 2006 Defender 110 Td5 SW Blenheim Silver
Hello
Are these brackets still available? I am interested in one for three switches.
Best regards,
Pajak
Post #971508 17th Nov 2022 9:25pm
LR Nuts
the same switches were used in the Freelander 1
Only available bank of switches was of 4
https://www.ebay.co.uk/itm/374354843160?ha...R66D-PiQYQ
also available in black
Post #971511 17th Nov 2022 9:52pm
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Is a 6 available if these are being printed?
3x3 over and under…
Post #974613 13th Dec 2022 10:44pm
gumdrop
Hi Andy,
I tried contacting you by email - do you have any of the single holders left?
I too would be interested in a custom switch holder for 5 switches.
Cheers,
Simon Cheers
Simon
50th D90 - my toy!
Freelander SE Td4 3 door - local run around
1958 Series 1- Rag top!
Post #974734 15th Dec 2022 10:37am
andyrad
United Kingdom 2004 Defender 110 Td5 XS CSW Bonatti Grey
Hi Andy,
can you do a custom bezel? im looking for a 3 way bezel, elec windows on the outside and a vertical hazards switch (RR classic) in the middle - any chance of this?
Thanks
Andy
Post #1014048 5th Nov 2023 10:27pm
mcma1
Hi Andy,
Yes I could although I would need the hazard switch or is it just the same as a TDCI switch? Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #1014516 9th Nov 2023 9:00am
andyrad
It looks the same as the tdci, 27mm x 37mm but in portrait.
this is what I'm trying to do, picture attached (I Hope) but not sure how wide your bezel will be. the gap between the hazard switch and the window switch is 17mm and the gap from the window switch to the USB/12v is only 12mm.
I could use the smaller Discovery 2 hazard switch (which I think looks a bit neater) - but I need to add in extra relays to make this switch work.
I can send you the hazard switch if it helps
Thanks
Andy
Post #1014529 9th Nov 2023 11:33am
mcma1
Can you give a basic drawing of that with the dims across the surround and switches? I can model it up here quickly and send you some images. Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1014665 10th Nov 2023 10:10am
mcma1
Thanks
Andy
sorry just seen you added some dims Andy
2014 Corris 110 SW
LS3 V8 build...
Post #1014672 10th Nov 2023 10:35am
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Hi Andy,
Similar question to Yannis, is a 3 over 3 panel possible?
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #1014701 10th Nov 2023 2:08pm
